  1. Nov 10, 2019 at 2:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I see you too are a man of supression
  2. Nov 10, 2019 at 2:07 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Rotated my tires and troubleshooted a noise I found in the suspension while searching out a different noise in the steering. Turns out I have to remove the 1/2" spacer on the driver's side coilover and replace it with a 1/4" spacer. I am getting an extra 1/2" of droop on the driver's side causing the Camburg uniball to bind. It has a small (very small) amount of play in it. I assume because of the excessive down travel. The passenger side has a 1/4" spacer so I will remove that and replace the driver's side 1/2” with the 1/4” and all should be good. The passenger side is not binding on the uniball so that is how I figured I can just move it over. Fun stuff.
  3. Nov 10, 2019 at 2:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Another good day driving. Really excited to have this truck running well again, between the front suspension and fixing the breaks it's like a totally different truck. I might have to wait another two weeks to do the drums but they work for now.
    NUDRAT, bmf4069, lsaami and 3 others like this.
  4. Nov 10, 2019 at 2:15 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Well starter lasted 10 days.... went up to my house I’m building was inside for 30 min came out and just get relay clucking. Starter is totally dead in the water, I was really hoping Napa had better quality than that.
    Any suggestions on what I should have the mechanic put in there for the next once since he will be pulling this damn thing out again?
  5. Nov 10, 2019 at 2:17 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Can you just rebuild your stock starter?????
  6. Nov 10, 2019 at 2:18 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Not if they took it as core.
  7. Nov 10, 2019 at 2:21 PM
    Filthyphil
    Phil
    they wouldn’t warranty the labor to replace it if I got it rebuilt.
  8. Nov 10, 2019 at 2:27 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    And in my typical fashion it's a form 1. I should have taken my home built AK to round out the package.
    Might not be bad to look into some limit straps. Binding joints is never fun. Straps are maybe $40-50 a pair.
    I have to add this cool picture. Very cool old bridge that's still holding trains almost 100 years later
  9. Nov 10, 2019 at 2:30 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I thought about that but I'd rather try removing the spacer from driver side, replace with the passenger side spacer and crank up the coilovers some more first. I also don't have a welder nor the ability to lay a nice bead. Haha
  10. Nov 10, 2019 at 2:32 PM
    KarmaKannon
    Utah
    Some junk
    I think it could all be bolt on. Let me see if I can find a picture of take a picture to give you an idea, but I swear I've seen someone use existing holes to mount a limit strap or at least drill new ones and bolt them on.
    MDobb79[QUOTED] likes this.
  11. Nov 10, 2019 at 2:34 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Also, a man of suppression. Had to remove all the rifles to get to the last upper that received a new lower so took a quick pic. Missing a few of the family members but close enough.20191022_180533.jpg
  12. Nov 10, 2019 at 2:44 PM
    I have never seen a suppressed AK. Well done sir. :hattip:
    KarmaKannon[QUOTED] likes this.
  13. Nov 10, 2019 at 2:48 PM
    Fred
    Hand Protectors
  14. Nov 10, 2019 at 2:52 PM
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    It is sometimes, but sometimes it's just under power and it feels like the truck is surging.
  15. Nov 10, 2019 at 3:00 PM
    Fred
    Hand Protectors
    I wonder what could fit here with a little surgery?
    Darkness and FrenchToasty like this.
  16. Nov 10, 2019 at 3:22 PM
    empty_lord
    05 rollover special
    Nice. I went from 4 for my 5.56 suppressor. Troy quick attach titanium. 600 wasn’t so bad for it i think.
  17. Nov 10, 2019 at 3:24 PM
    empty_lord
    05 rollover special
    Nice here’s my only suppressor as of now
    I’ve got plenty of ars I’ve built
  18. Nov 10, 2019 at 4:01 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Gun!!
  19. Nov 10, 2019 at 4:08 PM
    Fred
    Hand Protectors
    I was thinking my hand hyperbaric compression chamber.
    MDobb79, CodyP, bmf4069 and 5 others like this.
  20. Nov 10, 2019 at 4:22 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    If you're referring to the secondary air Injection pump, I have a bypass on that
    because_wumbo-truck likes this.
  21. Nov 10, 2019 at 4:24 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Only on 04-06???
  22. Nov 10, 2019 at 4:25 PM
    Hooptytrix
    Dirty South
    Something like that
  23. Nov 10, 2019 at 4:26 PM
    05-06 only I think. I thought it was only on VVTI models but may be wrong on that.
    Filthyphil and Darkness like this.
  24. Nov 10, 2019 at 4:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This is correct
    TX-TRD1stGEN likes this.
  25. Nov 10, 2019 at 4:31 PM
    empty_lord
    05 rollover special
    Yes
  26. Nov 10, 2019 at 4:59 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Did I miss something? I just see 2 AKs neither is suppressed :confused:
    Edit: nvn I was looking at the next gun pic several posts down. Carry on.
  27. Nov 10, 2019 at 5:03 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Hand stuff? ie: hand gun, hand creme, hand sanitizer
  28. Nov 10, 2019 at 5:04 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Tell me more.
  29. Nov 10, 2019 at 5:05 PM
    empty_lord
    05 rollover special
    I’m still trying to figure out what I can stuff in the sunglasses holder. Thinking about a tiny survival kit with a knife and shit... I don’t wear sunglasses sooo it’s u used real estate
  30. Nov 10, 2019 at 5:05 PM
    empty_lord
    05 rollover special
    Hewitt tech makes a bypass.
    I want to try and remove it all if I can figure out a way. The Hewitt tech leaves all the stuff there but adds block off plates to the tubes to
    The headers
