DIY: LED DRL/Turn Signal with resistor install
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 9, 2016.
  1. Mar 9, 2016 at 8:58 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This install was completed on my 2012 2nd Gen Tundra. Install will be similar for the 3rd Gen Tundras but i dont have confirmation the wire colors are the same.
    LEDs purchased from csjumper2003 on TacomaWorld.com. Here is his vendor page: https://www.tacomaworld.com/forums/jumpers-leds.171/
    This kit includes:
    (2) 4157NA LEDs
    (2) resistors with male connectors installed
    (4) t-tap connectors
    (4) self tapping screws
    Comparison between stock 4157NA bulb and new LED
    Diagram i found online for the resister install. Will be a little different on the Tundra as the wire colors are different. There is a ground wire, DRL wire and turn signal wire. It is very important to find the correct wires. If you tie the resistor into the DRL wire then the power will be running through the resistor all the time and it will get very hot and possibly fail or cause damage.
    The correct wires to tie into on the passenger side are the pink wire and the white wire with black line. Use the provided T-tap connectors to splice into these wires and connect the resistors.
    The correct wires to tie into on the drivers side are the red wire and the white wire with black line.Use the provided T-tap connectorsto splice into these wires and connect the resistors.
    Stock DRL
    LED DRL
    Resistors installed using the provided self tapping screws. Just find a good spot on the metal to install them where the resistor is not touching wiring or plastic.
    The stock bulb is on the left. The new LED is on the right ~5' away from the wall.
    Completed pic with DRL and halos on at night. Cant turn off the halos.
  2. Mar 9, 2016 at 9:13 AM
    csuviper
    Broomfield, CO
    If you do not have the kit as described above then you will need the following items
    (2) 4157NA LEDs
    (2) resistors
    (4) t-tap connectors and (4) male connectors of same size. Size is indicated by color. The correct color would be blue.
  3. Mar 9, 2016 at 7:12 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Awesome write up. Another mod to add to the to do list.
  4. Mar 9, 2016 at 7:17 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Good stuff man!
  5. Mar 10, 2016 at 6:13 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Your truck is so sick! Great thread.
  6. Mar 10, 2016 at 6:19 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I got some Amber LEDs to do this but I got the led rated flasher instead of the resistors.... Anyone know where the flasher is located?
  7. Mar 11, 2016 at 3:04 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I thought there were no LED rated flashers for 2nd gen. Where did you get it?
  8. Mar 11, 2016 at 3:07 PM
    Virgils12
  9. Mar 11, 2016 at 3:11 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Thanks I'm gonna order one.
  10. Mar 11, 2016 at 3:13 PM
    Virgils12
    I can't figure out where it goes... Have looked on both fuse boxed and they say nothing about a flasher.
  11. Mar 11, 2016 at 3:43 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Your flasher should be mounted on the back side of the fuse box under the dash...most of the time you have to unbolt the fuse box to gain access to it.
  12. May 6, 2016 at 7:59 AM
    King Slayer
    King Slayer New Member
    Northwest
    2016 TRD Tundra
    Custom powder coated gun metal TRD wheels, Michelin Defender 265x70's (better road & tow tires), Bilstein 5100 shocks with front adjusters, rear anti-sway bar, TRD Pro color match grille, TRD Pro (blacked out) headlights, color match tailgate handle, VLED replacement bulbs all around, Leer 100 XQ canopy, Katzkin leather.
    FYI: The VLED setup has a plug and play resistor pack with the LED controller. No wire cutting! I did mine with white DRL and amber switch back turn signals. Love it... http://www.vleds.com/
    white offroad likes this.
  13. Feb 1, 2017 at 9:31 AM
    Grin179
    Grin179 New Member
    2010 tundra platnium 4x4
    3" level kit 33" nitto trail grapplers Volant cai MagnaFlow exhaust Train horn with 165 psi
    Quick question fellow toyota guys... I just installed the resistors for the rapid flash issue... they are 6ohm.. so I installed one for each light. So I have 4 total. In the front passenger I got onto the pink wire and the white with black wire.
    On the driver side I got onto red wire and the white with black wire.
    Did I do the install correct? The rapid flash stopped but notice the resistors get really hot. I know it's normal the heat build up, but isn't it only going to get power when I turn the blinker on? Or constant?
    The back only had two wires each side.
  14. May 2, 2017 at 9:31 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    wonder if this will work on the 3rd gen?
  15. Nov 10, 2019 at 12:22 PM
    Dogmatic
    Dogmatic 2013 TRD Rock Warrior 4X4
    I just found this on Amazon...
    Is the flasher at the fuse box?
