Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Jul 3, 2019 at 1:05 PM
    #211
    wayoutwanderer
    wayoutwanderer @wayoutwanderer
    Austin, Texas
    2019 Tundra Limited CrewMax 4x4 in Cavalry Blue
    Haha, thanks.
  2. Jul 4, 2019 at 4:27 AM
    #212
    Bigbird57
    Bigbird57 New Member
    I am running 32's until they wear our.
    Then the 285/75-18 's will go on!
  3. Jul 12, 2019 at 12:56 PM
    #213
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I just can't help but wonder if these CAT tires will fit. I think it will be bad ass.
    F.N.G MOTO and yoshi82 like this.
  4. Aug 14, 2019 at 1:54 PM
    #214
    Rich31269
    Rich31269 New Member
  5. Oct 29, 2019 at 2:44 PM
    #215
    rocky91890
    rocky91890 New Member
    2012 Tundra Rock Warrior
    Sorry for being my first post, but couldn't find my answer thus far.
    I currently have a 2012 with the rock warrior package currently all stock, and am looking to swap out rims. currently the tires on it are 285/70/17s. I'm looking at a set of 18" rims was a +12 offset, and most likely would run 285/65/18s for the tires as this is almost the same overall as the current wheels(from what i saw on a tire size comparison visualizer)
    Just wondering if this should be doable without any modifications, or should i be looking at other rims
    Thank you
    roy2015 and yoshi82 like this.
  6. Oct 30, 2019 at 3:44 PM
    #216
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    I order a set today and I when with 295/70 R18, will be posting next week. But I have did some research and 295 is the max u can do with cutting nothing. Really wanted to go 35’s but didn’t want that extra work neither.
  7. Oct 30, 2019 at 4:26 PM
    #217
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    I'll take those rock warrior rims if possible
    equin likes this.
  8. Nov 4, 2019 at 10:38 AM
    #218
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Question. I have factory tires and rims, I do not want any lift or leveling kit. original tires are 275/55/R20 and I understand that I can put 275/60/R20 without any modification or trimming required. My question is, can I put 285/60/R20 without a lift kit, what kind of modification will I have to do to make them fit. I do not mind losing the small mud flap in front of the tire but would like to not have to do any other cutting or trimming, is that possible? If not, what will I have to trim to make this work. the 285/60 are 4/10 of an inch wider and 1.5 " taller than stock. The 275-60/R20 are 1" taller but no wider. I can not imagine how 4/10 wider and .5" taller can make that much difference than the than 275/60's on stock wheels without a lift kit. Has anyone tried this? What do you have to trim?
    Thanks in advance
    roy2015 likes this.
  9. Nov 5, 2019 at 11:00 AM
    #219
    tfsnowrider
    tfsnowrider New Member
    Tom
    Check out customwheeloffset.com. Go the the gallery and put in your specs. They have dozens of pics with different sizes, offsets, etc. Plus a description on if they had to trim and if it rubs. They're usually all for aftermarket wheels specified by diameter, width and offset so you may need to look up those specs for your stock rims.
  10. Nov 8, 2019 at 1:13 PM
    #220
    rocky91890
    Still haven't been able to find an answer towards it, but if it helps, the rims I'm looking at are the Black Rhino Roku rims in bronze and 18x9.5 +12
  11. Nov 9, 2019 at 8:53 AM
    #221
    Tun_Of_A_Gun
    Tun_Of_A_Gun New Member
    Jeff
    Central Florida
    2019 Cement CrewMax 4x4
    285/70/17 Ridge Grapplers 17” Method Wheels “0” Offset Black Emblem Over Predator Running Boards
    I searched for awhile on this thread and similar ones. I went ahead and pulled the trigger without confirmation. But I have 100% stock suspension on 2019 SR5 4x4. I went with Method 17x8.5 with 0 offset. I was really hoping to achieve an inch or two no more no less outside stock fender. Tires I went with a 285/70R17. I was fully prepared to have BMC and or front bumper trimming. I couldn’t be HAPPIER with how it turned out EXACTLY what I was hoping for. No BMC needed. Slight front bumper rub in reverse either side. I did use a heat gun to push bumper liner forward slightly.
  12. Nov 10, 2019 at 3:54 PM
    #222
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Can you take a pic from the side? I was always under the assumption 285/70/17 would look too small, but those look good from the pics.
  13. Nov 15, 2019 at 5:28 PM
    #223
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Truck looks great! Might go this route! More pics please!
    Tun_Of_A_Gun[QUOTED] likes this.
  14. Nov 18, 2019 at 6:44 AM
    #224
    Tun_Of_A_Gun
    Jeff
    Central Florida
    Thanks !! I’ll snap some more pics when I get a chance to have a decent back drop lol..
    Berdine[QUOTED] likes this.
  15. Nov 18, 2019 at 9:23 AM
    #225
    Boerseun
    Ferdie
    Sarasota Florida
    I agree; that looks good. 285/70/17 is just shy of a 33" tire. I think that's the perfect size for an unlifted truck.
  16. Nov 23, 2019 at 12:57 PM
    #226
    52Tundra80
    52Tundra80 New Member
    Jay
    Mile High
    20’ CM SX super white
    Just put Nitto Grappler 285/65r18 on my stock sr5 CM and no rubbing at all so trimming does not appear to be necessary at all. Thanks for all the answers as this forum helped me make my decision, even though the dealer tried to scare me out of moving up tire size
    Rdh1223 likes this.
  17. Dec 12, 2019 at 6:16 PM
    #227
    favStaR
    favStaR New Member
    2020 Tundra TRD Sport Premium
    pics?
  18. Dec 27, 2019 at 9:08 AM
    #228
    Oscar1979
    Oscar1979 New Member
    Oscar
    Mesa, AZ
    Tundra SR5
    Tires
    2020 SR5 stock suspension. Went with 18x9 Fuel Vapors and 33x12.5 Nitto ridge grapplers. Didn't have rubbing at first, but after 100 miles got some. Rub while tacke hard right or backing up and turning wheel either side. Should have read thread before hand. Next is a 2.5" Bilstein 6112 and 5160 lift. Debating on back lift to keep rake. But that will wait until I get some overtime in.
    Berdine and jewsNbrews like this.
  19. Jan 17, 2020 at 12:51 PM
    #229
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    costco's running a deal on ko2's... anybody running 285/65/18s on stock suspension? pics? thx
    TheBeast and 2018Tundra like this.
  20. Jan 17, 2020 at 1:21 PM
    #230
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    Here you go.
    splitfuse, Baja Mike, eddie98 and 3 others like this.
  21. Jan 17, 2020 at 1:25 PM
    #231
    TheBeast
    TheBeast The Beach
    I priced the 35"s K02 at $1250 ish mounted. Not bad imo.
    Spitfire[QUOTED] and porkitt like this.
  22. Jan 17, 2020 at 1:29 PM
    #232
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    What was the exact size?
  23. Jan 17, 2020 at 3:07 PM
    #233
    TheBeast
    TheBeast The Beach
    35x12.5 /18"
    porkitt[QUOTED] likes this.
  24. Jan 17, 2020 at 3:43 PM
    #234
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Thanks, I just may squeeze the trigger on this
    TheBeast[QUOTED] likes this.
  25. Jan 18, 2020 at 7:51 PM
    #235
    Spitfire
    Spitfire New Member
    Long Island
    No issues? Rubbing? Can u take a shot to see how they line up with fender? Want to see if or how much they stick out
    2018Tundra[QUOTED] likes this.
  26. Jan 20, 2020 at 6:52 AM
    #236
    2018Tundra
    VA
    Yep I'll do that later today if I don't forget! No issues at all and no rubbing!
    Spitfire[QUOTED] likes this.
  27. Jan 20, 2020 at 10:26 PM
    #237
    YotaBee
    YotaBee New Member
    Bee
    2019 Cement Tundra
    All around LEDs so far.
    Stock suspension with Falken Wildpeak M/T - 285/65/18. No rubbing at all.
  28. Jan 21, 2020 at 5:51 AM
    #238
    Spitfire
    Spitfire New Member
    Long Island
    looks really good
    YotaBee[QUOTED] likes this.
  29. Jan 25, 2020 at 7:06 AM
    #239
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    How is the road noise?
  30. Jan 25, 2020 at 7:18 AM
    #240
    YotaBee
    YotaBee New Member
    Bee
    2019 Cement Tundra
    Slightly noticeable. Doesn’t bug me one bit though. Was expecting a lot more noise.
