Current build
Discussion in '1st Gen Tundras (2000-2006)' started by shill2002, Nov 9, 2019.
  1. Nov 9, 2019 at 2:57 AM
    shill2002
    shill2002 [OP] New Member
    Beige 2002 Toyota Tundra
    Toytec alumna series 2.0 shocks Freedom off-road upper control arms Custom retrofits Custom grille 10” rf sub and amp
    B10183DD-10B4-4EF0-AE2E-151498F07FE9.jpg Bought this truck off of a close family friend about a year ago, so far I have new headlight housings, 2.5(front) 1.5(rear) leveling kit. Took off the muffler and redid trim. Also pout aftermarket fog lights in lower bumper. Any other suggestions as to what should come next?
    Rica25, jeremyd, Filthyphil and 5 others like this.
  2. Nov 9, 2019 at 4:56 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The clear coat on my Thunder Grey Metallic 2002 looks about as bad.
    Is your truck a V6?
  3. Nov 9, 2019 at 5:21 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  4. Nov 9, 2019 at 5:57 AM
    Check all the fluids and change them.
    If you live in a rust area check the frame for rust.
    Change the spark plugs and inspect the coils.
    If you dont have the history of the timing belt being changed buy the aisin kit off Amazon and change it and the water pump.
    Inspect and replace worn out suspension pieces.
    Being an 02 you have shitty WE calipers. Get the z32 WL kit off rock auto and swap em.
    Check your rear brakes and do the rear diff breather mod.
    Check the driveshaft for play and replace carrier bearing/u joints as needed.
    Check all interior lights and replace as needed.
    Most of this has a thread in the info dump thread up in the stickies. That should be a good start. Let us know what you find.
  5. Nov 23, 2019 at 4:19 PM
    shill2002
    Thanks for the tip. Mines a v8 but the clear coat has all but turned to dust. I’m in Cali so don’t need to worry too much about rust.
  6. Nov 24, 2019 at 8:29 AM
    Yeah, clear coat is an issue I've been seeing more and more of here lately.
  7. Nov 24, 2019 at 8:46 AM
    Professional Hand Model
    Fred
    Hand Protectors
    If you’d polish it every other day then this wouldn’t be a problem. :D
  8. Jan 5, 2020 at 2:12 AM
    shill2002
    Very true...thinking about wrapping the hood with vinyl and then re clearcoating all the other peeling places.
  9. Jan 5, 2020 at 2:14 AM
    shill2002
    So far it’s coming along pretty well.
  10. Jan 5, 2020 at 6:06 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Ga
    I'm almost talked into getting the darker light housings; love the look!!
  11. Jan 6, 2020 at 9:44 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Looks good! What grill is that?
  12. Jan 6, 2020 at 7:43 PM
    shill2002
    It’s the aps billet grille off of Amazon. Required some cutting and drilling but nothing a dremel couldn’t take care of!
    Filthyphil and TundraDude18 like this.
  13. Jan 6, 2020 at 7:43 PM
    shill2002
    Thank you, the housings aren’t quite as good of quality but I love the clarity on them.
  14. Jan 6, 2020 at 8:32 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Are you going to restore the trk, or use it as a 2nd vehicle beater.
  15. Jan 7, 2020 at 4:22 PM
    shill2002
    I’m restoring it and upgrading. I’m only in highschool so it’s slow going. Lol
  16. Jan 7, 2020 at 4:29 PM
    02goes
    02goes New Member
    If your high school offers vocational school classes and auto body repair is one of them, take the trk to them for a paint job.
  17. Jan 9, 2020 at 11:56 PM
    shill2002
    Good idea, I’ll check it out thanks for the tip.
