Steering wheel shake???
Discussion in '2.5 Gen Tundras (2014-2021)' started by CWCreas, Nov 4, 2019.
  1. Nov 4, 2019 at 10:12 AM
    CWCreas
    CWCreas [OP] New Member
    Clayton
    2017 TRD Pro with Readylift +4 lift. 35x12.5R20 Falken Wildpeak AT3s. After install of tires about 6k miles ago I noticed a significant steering wheel vibration. Took the truck back to tire shop and had tires balanced again. Was told that due to imitation bead lock design they had to static balance them and it wasn't as easy as conventional balancing. Moving forward everything seems smooth...except on random occasions I get a bad shake in the steering wheel after initial startup. Seems like after 5-10 miles it goes away and it's smooth from there on. It's got me puzzled because when I really notice it is when I leave work after truck has sat 8+ hours. Pull directly onto highway, wheel shakes for 5 minutes but by the time I hit the interstate it's smooth. It's almost like the tires have flat spots from sitting and have to "warm up" I don't notice it if I leave home, drive side roads for awhile then hit the highway. Very puzzling to me...any ideas?
  2. Nov 4, 2019 at 10:16 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    flat spotting
    GODZILLA, Sas and Nm6300'asl like this.
  3. Nov 4, 2019 at 2:07 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I have run mine in brutally cold weather after sitting all night and never had an issue. How much air are you running in these tires? I have mine set at 42lbs. Have you swapped from to rear? Any difference?
  4. Nov 4, 2019 at 2:44 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    What Joonbug said...
    joonbug likes this.
  5. Nov 4, 2019 at 5:26 PM
    Jessecr
    Jessecr New Member
    15 tundra CM
    My brand new 20” wildpeaks do the exact same thing, seems like they are out of balance (bad steering wheel shake) for the first five miles after it has sat for a couple days then smooth as butter.
  6. Nov 4, 2019 at 5:39 PM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    I’d be leaning towards flat spots
  7. Nov 4, 2019 at 6:39 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Falken Wildpeak AT3s ... I read somewhere on this forum recently that they are bad at flat spotting ...
  8. Nov 5, 2019 at 8:19 AM
    CWCreas
    Clayton
    Well as annoying as it is I'm glad to hear that. I'll deal with the flat spotting over front end issues etc. Thanks guys.
  9. Nov 5, 2019 at 8:27 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    This. My Nitto Ridge Grapplers will do this too if I don't drive the truck for a few days.
  10. Nov 5, 2019 at 10:12 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Wow, just had my rotors checked because I have vibrations. Thought it might be my tires but wasn’t sure. I also run Wildpeaks. Good to know it’s not my brakes.
  11. Nov 5, 2019 at 12:01 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Worn out rotors can cause this as well. I was convinced my '16 needed new ball joints or shocks recently. After turning my rotors three times they had had enough and the steering wheel was shaking all the time. Got new front rotors and smooth again.
  12. Nov 5, 2019 at 12:04 PM
    JeremyGSU
    Jeremy
    2016 Tundra
    My '16 does this with stock 18" wheels/tires. I live within .6 miles of the interstate and when I would go to work I was often convinced I had slung wheel weights or they were grossly out of balance. I thought there was no way it could be shaking this bad from over night only to have them ride smooth as butter in the afternoon even after sitting all day. The ambient temp can play a big diff in my experience too, especially if you road force balance your tires.
  13. Nov 5, 2019 at 5:44 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    My 18 does this, it’s not the tires in my opinion. I have ran 3 different sets of wheels and tires and all do it. I just chose to live with it, goes away quickly.
  14. Nov 6, 2019 at 12:23 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Tires with nylon cords built into the carcass will flat spot like that.
    I had a customer with 285/45/22 Bridgestone Duelers on a Chevy 1500.
    We balanced them multiple times and he kept coming back saying they felt like they were flat spotting because the vibration would go away after warming up.
    We switched him to a set of Michelin Defenders in the same size and because they have cotton cords vs nylon cords his issue was resolved.
    jtwags likes this.
  15. Nov 6, 2019 at 3:39 AM
    Omohundro
    Jody
    McMinnville TN
    How does one find out what tires have nylon vrs cotton cords? I’ll try to make sure my next set are cotton.
  16. Nov 6, 2019 at 7:21 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I noticed this on my 2019 with only 1700 miles the other day I parked it overnight outside and drove it the most morning when it was cold. Like everyone else, it went away after the truck warmed up.
  17. Nov 6, 2019 at 8:23 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The sidewall of the tire will tell you.
    GODZILLA likes this.
  18. Nov 8, 2019 at 2:18 PM
    Bigjoe7757
    Bigjoe7757 New Member
    2021 Tundra CrewMax TRD Sport
    My 18 Crew does this also and it drives me nuts, my 15 Tacoma did it so much that after several attempts to balance the tires I traded it for the tundra.
