AlphaRex HLs
Discussion in 'Lighting' started by texasrho83, Aug 1, 2019.
  1. Aug 1, 2019 at 7:16 AM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  2. Aug 1, 2019 at 7:19 AM
    Always something new coming along, nice, but not for me
  3. Aug 1, 2019 at 7:25 AM
    blizz86
    blizz86 New Member
    These look like a wannabe GMC headlight.. i highly doubt the output is better than the stock reflectors. Morimoto just released their dual low beam projector + single hi projector. Output likely beats the bricks off this thing as its already much better than the OEM 2018+ leds.
  4. Aug 1, 2019 at 7:33 AM
    phabej
    phabej New Member
    2018 Platnium
    eww halogens
    "The headlights are using H7 halogen bulbs for low and build-in LED for high beam, customers can upgrade to Xenon HID and LED conversion kit with minor modification"
  5. Aug 1, 2019 at 7:41 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    If it offers an easy swap to a higher end bixenon projector it could be a good option... $370 is not bad at all - the typical complaint about the 18+ OEM LED is lightning performance versus HID setups like LS430, TSX, etc. projectors
  6. Aug 1, 2019 at 7:42 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pre-2018 most of the stock HLs came with Halogens
  7. Aug 1, 2019 at 7:43 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think the LEDs in the 18+ lights are good. No complaints here.
    Blueknights75, Sas and Okietundra like this.
  8. Aug 1, 2019 at 7:45 AM
    blizz86
    blizz86 New Member
    sticking an hid into a projector developed for halogens is only slightly better than sticking them into reflector housings. if you want GOOD light distribution, you're going to want real Hid projectors.
    i think hes saying, whats the point of spending 300 for the same performance as stock..
  9. Aug 1, 2019 at 7:48 AM
    ninjajay
    Spoolston, TX
    I'm talking about removing the projectors it comes with and bolting in real ones. If its possible, $370+cost of projectors gets you basically the rest of the custom work you'd do to stock housings like LED DRL while keeping your originals intact
  10. Aug 1, 2019 at 8:29 AM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    This is the beam pattern using an HID bulb. The housing doesn’t need look like a Tundra, but maybe it uses the same projector as the one in the Tundra. This is from their website.
    Rica25 likes this.
  11. Aug 21, 2019 at 10:15 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I was the first customer in the world to have their Full LED nova series in my F150. The customer support was great. the Light output and pattern were great.
    Rica25 likes this.
  12. Aug 21, 2019 at 10:59 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I don’t know about the lights, but can we all take a moment and reflect on how nice the Super white Tundra looks.
    Rica25 and Blueknights75 like this.
  13. Nov 7, 2019 at 7:32 PM
    Blueknights75
    Ron
    Clayton, NC
    X2...love my factory LEDs
  14. Nov 7, 2019 at 7:33 PM
    Blueknights75
    Ron
    Clayton, NC
    :amen:
    Rica25 likes this.
