2020 Tundras Calendar Submission - 2nd Generation Tundras
Discussion in 'Photography' started by ramonortiz55, Nov 4, 2019.
Thread Status:
Not open for further replies.
  1. Nov 4, 2019 at 11:57 AM
    ramonortiz55
    ramonortiz55 [OP] I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    Submissions end: November 11th
    Voting starts: November 12th - November 18th
    Before posting any submissions, please read the first few posts here. You may also post any BS, questions, comments, etc in the following thread:
    https://www.tundras.com/threads/2020-tundras-com-calendar-submission-information.55205/
    Each participant is able to post up to two pictures of their build. If a participant has more than one build, he can submit two pictures of each build currently owned.
    **If submitting TWO pictures, submit them as separate posts**
    **You may nominate someone's build or picture HERE , the owner of the build/picture may then post on the submission thread**
    **If you are a photographer, please make sure you have consent of the Tundra owner to submit their picture. Consent must be publicly provided in the link above and the rules in the link above still apply (must be an active member on Tundras)**
    **Participant must be a member of Tundras, having a build thread is NOT a requirement**
    **When voting starts, you may vote as many times as you want. Moderators will be tiebreakers. Tiebreakers may or may not be done anonymously**
    Remember the following rules:
    1. One picture per post, per participant. If you have two pictures or more than one build, post ONE picture per post. This will make voting easier.
    2. Please, NO BS, chit chat, critiques, etc in submission threads.
    3. Refrain from hitting "Like" until submission of all photos have been completed and thread locks.
    4. You are allowed to do some editing, but don't go crazy.
    5. Keep it safe for work. We don't want to see your hot wife in a bikini washing the truck.
    6. You will need a high resolution version of your photo for calendar production. If you can't submit a good enough photo, a runner up will take your place. Sorry, we can't have any delays.
    7. Please do not post any descriptions during submissions. Just post a picture, simple as that.
    8. Everyone has one week to submit a picture and/or vote. Once this process is over, it is over. Too late. No cigar.
    9. Moderators have all the right to delete submissions and or modify these rules.
    10. If you post more than two pictures, your full submission will be disqualified, even if you received the most votes. There will be NO warning.
    11. Let's have fun!
  2. Nov 4, 2019 at 11:58 AM
    ramonortiz55
    Ramon
    Any voting done between now and closing period will be cleared by the moderators when thread locks.
    Thank you.
  3. Nov 4, 2019 at 1:08 PM
    War Machine
    War Machine SSEM # 5 3MW
  4. Nov 4, 2019 at 1:09 PM
    War Machine
  5. Nov 7, 2019 at 12:24 PM
  6. Nov 7, 2019 at 12:26 PM
  7. Nov 7, 2019 at 12:32 PM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
  8. Nov 7, 2019 at 1:09 PM
    TheBeast
    TheBeast The Beach
  9. Nov 7, 2019 at 1:10 PM
    TheBeast
    TheBeast The Beach
  10. Nov 7, 2019 at 7:07 PM
    Rica25
    Ricardo
    Tulare
  11. Nov 7, 2019 at 8:56 PM
    Parrothead_DFW
    Parrothead_DFW Fins Up!
    Ron
    Grapevine, Texas
    2012 Tundra, Texas Edtion
    Eight spoke wheels, cargo netting.
  12. Nov 8, 2019 at 5:41 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
  13. Nov 8, 2019 at 10:48 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
  14. Nov 8, 2019 at 3:24 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
  15. Nov 8, 2019 at 3:49 PM
    airosey
  16. Nov 9, 2019 at 11:11 AM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
  17. Nov 9, 2019 at 12:05 PM
    NE_WARRIOR
    Union, ME
    08 DC SR5
  18. Nov 10, 2019 at 4:11 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  19. Nov 10, 2019 at 6:09 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
  20. Nov 10, 2019 at 6:18 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
  21. Nov 10, 2019 at 6:30 PM
    Parrothead_DFW
    Ron
    Grapevine, Texas
  22. Nov 11, 2019 at 9:41 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
  23. Nov 11, 2019 at 9:42 AM
    Kerch71
    Mechanicsville VA
  24. Nov 11, 2019 at 10:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
Thread Status:
