2016 front blinker and running lights overheating,amber- help
Discussion in 'Lighting' started by Tdogdad, Nov 3, 2019.
  1. Nov 3, 2019 at 12:46 PM
    Tdogdad
    Tdogdad [OP] New Member
    Tom
    South Jersey
    2016 black tundra sr5
    none
    Went to change out a front blinker and noticed the light socket had burn marks on both sides. Checked the other blinker and noticed the same. what is the fix? can i just go to LED's?
  2. Nov 7, 2019 at 8:41 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    There was a recall or TSB for Tacoma's about a similar issue years back.
    I would suggest googling and researching that issue and the fix.
    If you are still within warranty I would probably just take it to the dealer.
    Hell, even if you aren't, a burnt light socket is no joke and definitely a safety issue. Worth taking it in and politely asking a service manager about it. Mention that a burnt down truck is not good PR for Toyota.
    GODZILLA likes this.
  3. Nov 7, 2019 at 9:40 AM
    That is common for alot of vehicles. All the dealer will do is replace the socket. They are around $10.00 or so. I had to replace one of mine because the contact rusted out. You can go with an LED. VLeds is highly recommended. Dont use cheap ones from auto parts stores or Amazon. The socket is #7 and is $7.78. Do it yourself so they dont charge you labor. https://www.sparksparts.com/auto-pa...ngine/electrical-cat/headlamp-components-scat
