2018 Platinum CM OEM LED Fog Lights Shake
Discussion in 'Lighting' started by nodak67, Jul 25, 2018.
  1. Jul 25, 2018 at 2:19 PM
    nodak67
    nodak67 [OP] New Member
    JR
    as the title suggests, recently the driver side fog light assembly has started to shake over bumps and what not. the passenger side is a little loose but not to the same degree.
    I have searched the forums and came across issues similar but that was due to changing the end caps or putting in led lights that didn't come with the truck originally.
    anyone else having this issue?
    the driver side housing moves from side to side maybe 1/4" and the passenger side maybe 1/16".
    or should I go back and re-read the other threads again.
  2. Jul 25, 2018 at 3:28 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Have you taken the fender liner off to see that the 2 screws that hold the housing are intact and tight, or why it might be loose? The arms for these screws are also fragile.
  3. Aug 3, 2018 at 7:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  4. Oct 15, 2019 at 2:00 PM
    Taco2tundra12
    Taco2tundra12 New Member
    Blake
    2018 super white platinum tundra 4x4
    I have a 2018 tundra platinum and my situation is identical to yours. I have noticed it for months even to the point where I just don’t use my fog lights because it bothers me so bad. I finally remembered to say something to my dealership at my 15k mile service and when I picked up the truck o was told the lights are mounted “plastic to plastic, and there was nothing they could tighten”. I find it very hard to believe seeing as how my driver side shifts drastically more than the passenger. If they were mounted the same wouldn’t they move the same amount? Anyways not really sure what to do, after market lights? Maybe. I find it a little ridiculous that a truck this expensive has shaken fog light housing.
  5. Nov 6, 2019 at 6:42 PM
    Rand7777
    Rand7777 New Member
    South Texas
    2018 MGM Platinum
    I put a zip tie from the rear of the fog light to the bumper frame and that took all the movement out. Now when i go over bumps the fogs dont wiggle
    bvia likes this.
