2017 tundra clock
Discussion in 'General Tundra Discussion' started by homesteader, Nov 5, 2019.
  1. Nov 5, 2019 at 4:51 PM
    homesteader
    homesteader [OP] New Member
    If I don't start my tundra for a few weeks the clock is way off. It shows the wrong time to an even hour (9:00, 1:00).
    The battery is good, engine turns over easily, everything else works fine. No big deal to reset the clock but annoying. Also, if this is not supposed to happen I want to get it fixed.
    Could this be intentional to save the battery?
  2. Nov 5, 2019 at 7:07 PM
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    Remember reading about this same problem on another site. Owner kept going to the dealer and was told "it is okay". Finally, Toyota replaced the clock and problem fixed.
    Probably some bad/flaky circuit board in your clock module. Hope you get it solved.
  3. Nov 5, 2019 at 7:18 PM
    homesteader
    I will check it out in 3 weeks, then 2 weeks, to see if it is definitely time related.
  4. Nov 5, 2019 at 8:14 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I wonder if head units have a tiny battery in them that keep track of that kind of stuff like motherboards do? I don't recall having to reset the clock or my radio stations whenever I disconnected the battery to do some upgrades.
    easleycrawler likes this.
  5. Nov 6, 2019 at 3:55 PM
    homesteader
    Some electrical components store electricity for a period. I have some appliances with clocks that will keep time for a while when unplugged; they have no batteries.
