  1. Nov 4, 2019 at 6:33 PM
    Possibly a stupid question but how does one drain the MC specifically? Is there a bleeder valve on it?
    Darkness likes this.
  2. Nov 4, 2019 at 6:42 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, would be nice if there was. There should be bleeder valves all over the damn ABS system.
    You have to disconnect the two output lines on the master cylinder, attach some threaded nipples where the lines were, put tubes on those nipples and loop them back into the fluid reservoir. Have somebody push the pedal slowly while you watch for bubbles. Have them let off slowly, wait about 15 seconds and repeat. When no more bubbles come out you're good, now remove the contraptions and reconnect the brake lines. Then bleed all 4 corners and the proportion valve.
    Went for a mild test run on my street. It stops just fine at 5 mph, get it up to 20 mph and it's a different story. Brake pedal gets hard but brakes don't grab. I'm curious if the hose on the vacuum port is cracked and not feeding the booster or what. Otherwise maybe this booster is busted. Going to try replacing that tomorrow and check my drums for adjustment.
    Any thoughts @empty_lord ? New booster and master cylinder, bled it all to hell, nomore bubbles.
    @FrenchToasty haven't got that far yet, I can't get to the dirt road as weak as these brakes are.
  3. Nov 4, 2019 at 6:49 PM
    Quick question, I didnt bleed the proportioning valve when I did all my brake stuff earlier this year? Should I have?
    @Darkness I had a d/c vacuum line that made my brakes hard to operate, but it was at highway speeds. Maybe that could be it?
  4. Nov 4, 2019 at 7:01 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I looked at the end that meets the booster, it's pretty deteriorated. I'm gonna see if I have some hose to replace it with.
    The brake proportion valve I've always been on the fence about. I do it just because it's easy, it's there, and I usually see some dirt and bubbles come out. If your brakes are fine I would leave it until next time.
  5. Nov 4, 2019 at 7:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Pedal hard but no brakes? Sounds like a bad check valve to the booster.
    Darkness[QUOTED] likes this.
  6. Nov 4, 2019 at 7:36 PM
    empty_lord
    05 rollover special
    Portioning valve only needs to be bled when your repacking the master or something further up the line.. simple brake flush’s and stuff I tend not to worry about them.
  7. Nov 4, 2019 at 7:56 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    These check valves can rotate right? It was aimed the wrong direction so I turned it a bit.
    TX-TRD1stGEN likes this.
  8. Nov 4, 2019 at 8:01 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I didn't bleed mine either time I changed the brake lines. I let the fluid run out of the master cylinder completely for the front half of the system. My pedal and brakes feel fine. I didn't even bleed the rear because that side of the master didn't run dry. Maybe that's the cutoff when someone has to bleed the proportioning valve?
  9. Nov 4, 2019 at 8:32 PM
    empty_lord
    05 rollover special
    Usually
  10. Nov 4, 2019 at 10:47 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Went to pickup a nearly new Dual Fuel Generator. Seller said he used it once, included full propane bottle. Runs on gas and propane. Should be able to make it run on Natural Gas also. This will replace the 2kw Coleman PowerMate I bought after the 1994 Northridge quake.20191104_212521.jpg 20191104_212525.jpg
    NUDRAT, hammeron and Darkness like this.
  11. Nov 5, 2019 at 3:02 AM
    KarmaKannon
    Utah
    Some junk
    Nice! I think this is the year I finally get one. Every 5-10 years we get a nice windy and cold storm around January that knocks power out for a couple days. One time my mom was sick and if we didn't have my dad's generator I don't know how she would have been. Simple things like some heat, ac, or clean clothes can be the difference between getting more sick or getting better. I think it's mostly a stress thing. Good call on the multiple fuel sources too!
  12. Nov 5, 2019 at 4:33 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those Champion gensets get rave reviews. Propane/NG is the way to go for a generator, no need to store and rotate gasoline, no worry of a crudded up carb from sitting too long either.
  13. Nov 5, 2019 at 5:35 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    Got my stickers from @boardude, thank you! The tuna is coming along.yoda.jpg yoda 2.jpg
  14. Nov 5, 2019 at 5:42 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Anyone installed one of these diff drop kits? Send inexpensive and should help front Drive line angles.
    because_wumbo-truck likes this.
  15. Nov 5, 2019 at 7:48 AM
    I installed Dirty Deeds Long tube headers.
    Actually, this was just a dream I had last night. You can imagine my disappointment when I woke up and realized it didn't happen. :annoyed:
    Tohopko, NUDRAT, Filthyphil and 5 others like this.
  16. Nov 5, 2019 at 7:50 AM
    I don't see a price on there but Toy Tech sells the diff drop kit for Before I added the ICON's in the front I was expecting to do this mod but my CV's are actually not at that crazy of an angle so I have opted to leave the diff alone.
  17. Nov 5, 2019 at 8:32 AM
    kodyquist21
    Kody
    Buckeye, AZ
    My right blinker is blinking like crazy, ive changed all the bulbs on the front and back and i even changed the fuse but it still has hyper speed blinking. does anyone else have this issue?
  18. Nov 5, 2019 at 9:16 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    You didn't replace with LEDs did you??
  19. Nov 5, 2019 at 9:18 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    29$$ in this site. I think I'm going to get and install it. The Tacoma guys all seem to like them.
  20. Nov 5, 2019 at 9:34 AM
    kodyquist21
    Kody
    Buckeye, AZ
    No, they were just normal halogens. ive seen multiple posts about LEDs doing that as well but mine are halogens. i thought it was the wiring harness so i ordered a new harness for the rear lights but its still doing it.
  21. Nov 5, 2019 at 10:16 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Wheelers sells it for super cheap. I think like $15
    Edit: NVM the price has gone up significantly since I last checked a year ago. That or my memory is just wrong lol
    I also planned to do one but opted not to.
  22. Nov 5, 2019 at 10:21 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Maybe the relay?
    I know when I did LEDs instead of adding resistors, I swapped the stock flasher relay for an led flasher relay. Maybe your stock relay is bad?
  23. Nov 5, 2019 at 11:02 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    :headbang:
    kodyquist21[QUOTED] likes this.
  24. Nov 5, 2019 at 11:06 AM
    empty_lord
    05 rollover special
    Man.. I have dreams of my trucks both being done and badass. Only to wake up and see 2 u finished projects
  25. Nov 5, 2019 at 11:51 AM
    kodyquist21
    Kody
    Buckeye, AZ
    that could defs be, i may have to take a look into it. it the grand scheme it's not damaging anything it's just really annoying to turn right hahah
  26. Nov 5, 2019 at 1:02 PM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I picked up the 6250 watt dual fuel during the last PG&E outage a couple weeks ago just to have as they talked about further outages later that week. Thought about keeping it, but the thing weighed a ton and was massive so I returned it for a inverter unit instead. I really only need to run my fridge and while the dual fuel would be nice, 1 gallon per 10 hours on the inverter should last me quite some time if needed. Hopefully that one works out for you.
  27. Nov 5, 2019 at 1:39 PM
    What does Yodagan mean?
  28. Nov 5, 2019 at 3:09 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Guessing it's a play on Hoonigan and Toyota
    boardude likes this.
  29. Nov 5, 2019 at 3:11 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah but they're badass projects
  30. Nov 5, 2019 at 3:50 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    a dream about installing headers on a 4.7 sounds more like a nightmare to me. Haha
