Different sized tires
Discussion in 'General Tundra Discussion' started by joonbug, Dec 15, 2016.
  1. Dec 15, 2016 at 9:01 AM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Okay, I definitely know driving with 1 smaller tire is bad. But how about if both the front or both the rears are smaller? Say you have 34.5" rears, would running 32" fronts do any damage in either 2WD or 4WD? My drive deep into the desert may be coming up and I'm wondering if I don't get a proper full size spare by then, can I just take 2 of my stock wheels? In the event of a flat, I'll just swap out both fronts or rears.
    Second question, what have you guys done for a full size spare? A 5 tire rotation would be nice but I'm not spending another $500 for another wheel. I was thinking about slapping on a cheaper tire onto my spare rim, has anyone done that?
  2. Dec 15, 2016 at 10:40 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Dec 15, 2016 at 10:50 AM
    Marty McFly
    Morty McBoonJug
    Make sure to post pics of spearmint when your "deep in the desert" ;)
    TheBeast and joonbug[OP] like this.
  4. Dec 15, 2016 at 11:14 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    If the Spearmint is anywhere nearby, I probably won't make it to the desert...
    Marty McFly[QUOTED] and T-Rex266 like this.
  5. Dec 15, 2016 at 11:19 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    In theory you could run a pair of smaller tires on the same axle in a pinch, but not in 4wd as rotations will be miss matched and cause drivetrain bind. You could potentially hurt/break something if running in 4wd, it would basically be like having mis-matched axle gears which is a no-no. You'd probably also get some lights on the dash thinking the tires are spinning at different speeds, probably give ABS/Traction control issues having mis-matched sizes
    Look into a 275/70/18 for under the truck, they're just over 33" and being within an inch of your regular tires would probably make them fine to run short-term as a spare to get to a tire shop.
  6. Dec 15, 2016 at 11:25 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, I figured the 4wd would be a no-no, but 2wd should be okay? My problem is, we're going up past Black Rock and the nearest shop is probably.... ummm.... your shop. LOL Uggggghhhh, I guess I'll just have to pony up for a full size soon. Thanks Eric
    TheBeast and Relentless[QUOTED] like this.
  7. Dec 18, 2016 at 8:40 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    If you want to fit a spare that's much larger than 32" into the stock location under the bed you'll have to cut two brackets off to make it fit. You can fit up to a 285 wide tire onto a stock 18x8" wheel and have no clearance problems on either axle. My 285/75R18 Exo Grapplers fit just fine on both axles and under the bed. Something with lugs that stick out like on a Toyo M/T would be problematic though. Perhaps you could buy a stock OE steel wheel if you're trying to do it on the cheap.
    joonbug[OP] likes this.
