Plastidipped grill and badges
Discussion in '1st Gen Tundras (2000-2006)' started by Tyler1524, Nov 3, 2019.
  1. Nov 3, 2019 at 10:04 AM
    Tyler1524
    Tyler1524 [OP] New Member
    Tyler
    2006 Tundra DC SR5 4WD
    I've always disliked the chrome bits on the grille and side view mirrors, figured I'd hit the badges as well because why not. Not sure how it will hold up, but the dip is super easy to peel if you don't like it. I ended up doing 5 coats, wasn't sure how I felt about the grille being all black so I peeled the body-colored portion.
    Darkness, Pat, marbleville and 3 others like this.
  2. Nov 3, 2019 at 10:08 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I think that looks cool, works well with that colour. Good work.
  3. Nov 3, 2019 at 10:54 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Looks good. I also dislike chrome but I took a different route. I replaced my badges with newer style black ones and painted the grill badge with bed liner from a spray can. IMG_20191103_104309976.jpg IMG_20191103_103643955.jpg IMG_20191103_103449749.jpg IMG_20191103_103425666.jpg
    Darkness, marbleville and KarmaKannon like this.
  4. Nov 3, 2019 at 11:03 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'm not a big fan of dip but I really like that look. I might have to change my chrome stuff up a little. I really like the way that grill looks.
  5. Nov 3, 2019 at 12:18 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice job man, I like it and think you'll be surprised how well it hold up as long as you have enough coats on it. I like how you peeled away the parts of the grill that are body color and just left the chrome areas black, I was thinking of saying you should peel those areas off when I saw the 1st pic, then I saw the progression of pics and you already did it. Nice work
  6. Nov 3, 2019 at 12:19 PM
    Pudge
    CT
    Those chome areas looks like they would be pretty easy to wrap, with either black or something close to color matched.
    Darkness and KarmaKannon[QUOTED] like this.
  7. Nov 4, 2019 at 3:06 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    @Tyler1524 Outstanding job! Although I am a chrome man, you did indeed put a broadside to my way of thinking. Well done.:cool:
  8. Nov 27, 2019 at 3:35 PM
    Obtunded
    Obtunded New Member
    San Antonio
    2016 Tundra CrewMax XPS-X 4x4
    Carbon fiber dash, leather seats
    My chrome grill on my 08 CM had two bubbles. It was annoying me enough to try to heat them up with a heat gun to see if it would smooth out. Instead, it made it worse. Im wondering if anyone knows what's under the chrome wrap and if it's plastic and if I can paint it. I was thinking of plastidip but if this chrome peels off it may turn out better.
  9. Nov 28, 2019 at 1:03 PM
    Professional Hand Model
    Fred
    Hand Protectors
    With the right attitude, patience, materials, and time anything is possible. I would suggest you use an Acrylic Lacquer rattle spray vs. plastic dips.
    Check my build page for some ideas or inspiration.
  10. Nov 28, 2019 at 7:06 PM
    Obtunded
    Obtunded New Member
    San Antonio
    This is what's under the chrome that peeled. It's black plastic. Took 10 minutes to remove it. Im gonna finish it tomorrow
    BravoDeltaRomeo and Darkness like this.
  11. Nov 29, 2019 at 6:03 AM
    Fred
    Hand Protectors
  12. Nov 29, 2019 at 6:25 AM
    bmf4069 Captain wtf
    Sir, I need you to cease and desist all posting of 2nd gen pics in the 1st gen(best gen) section.
    Darkness likes this.
  13. Nov 29, 2019 at 8:15 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    First gen grille strips arent quite the same. It doesn't peel off that way, if you sand through the chrome you'll find what appears to be a copper layer and there might be a nickle layer as well.
    I sanded mine down to look like brushed steel long ago (after 2 failed paint attempts and a bed liner job that lasted 5 years before chipping).
  14. Nov 29, 2019 at 8:33 AM
    Obtunded
    Obtunded New Member
    San Antonio
    This was completely by accident. I had a bubble and tried to smooth it out with a heat gun. It bubbled into more bubbles. A week later it had a little chip missing. I was planning on buying a replacement in black but then found plastic underneath the chrome. Now I'm just going to peal the rest which isn't hard and paint it
    bmf4069 likes this.
  15. Nov 29, 2019 at 8:43 AM
    Fred
    Hand Protectors
  16. Nov 29, 2019 at 9:07 AM
    Obtunded
    Obtunded New Member
    San Antonio
    Sorry. Thought I was on 2nd gen
  17. Nov 29, 2019 at 9:33 AM
    bmf4069 Captain wtf
    Happens all the time. It's my job to let people know. Head shoo'er if you will.
