How’d you secure your truck box in the bed?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blue Thunder, Nov 1, 2019.
  1. Nov 1, 2019 at 5:03 PM
    Blue Thunder
    Blue Thunder [OP] Smooth in the Cruise
    Washington
    Given the lack of storage in the cab, I’ve decided to keep my truck box in the bed. Plan to drill and bolt it down this weekend unless anyone has a better suggestion. Hate to drill holes, but can’t think of a better way.
    Looking for your ideas/solutions for securing truck box in bed!
  2. Nov 1, 2019 at 7:59 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    J hooks. No bed drilling necessary
  3. Nov 1, 2019 at 8:32 PM
    Blue Thunder
    Washington
    Sorry...forgot to state it’s not a box that hangs on the rails. It sits on the truck bed...
  4. Nov 2, 2019 at 6:10 AM
    PJR202
    PJR202 New Member
    Maybe it's a little late, but have you considered a swing case? They're a lot bigger inside than they look. I'm pretty happy with mine.
    texasrho83 likes this.
  5. Nov 2, 2019 at 6:12 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Maybe get some super strong magnets? Lol
  6. Nov 2, 2019 at 10:33 AM
    Omen
    Omen New Member
    I second this. I have a single swing case and am glad I didn't do the double. For my needs one was plenty. Either way, they keep things secured and out of the way. Yes, you have to drill, but it is a solid setup.
    PJR202[QUOTED] likes this.
  7. Nov 2, 2019 at 11:40 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I had one in my last truck. I just drilled through the bed and used fat washers underneath. Worked fine. Buuut if i were to do it over again, i would have used some steel hockey pucks to lift the box off the bed floor. This would have allowed me to blow out crap from underneath
  8. Nov 2, 2019 at 11:50 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Not sure if you’re open to buying a new box but someone on here bought one from tractor supply that lined up perfectly with existing bed bolts so no need to drill. Give a search and you should see what I’m talking about
    Blue Thunder[OP] likes this.
  9. Nov 2, 2019 at 12:03 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Same situation you are in. I've bought victory4x4 bedmounts. I will be using them to secure the bed box with chain. I have a zdog tool box.
  10. Nov 2, 2019 at 11:13 PM
    Blue Thunder
    Washington
    All great suggestions...thanks guys. I don’t think the swing boxes will have enough capacity. I’m going to look it over again tomorrow. Using the bed bolts might work too.
    I hate to say it, but an over the rails box might be the best option. No drilling and fairly easy to remove if needed.
  11. Nov 2, 2019 at 11:25 PM
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
  12. Nov 2, 2019 at 11:27 PM
    TheFreshMouse
    Mouse
    18 CM MGM
    Pinstripes
    That might be me :D
    Mater[QUOTED] likes this.
  13. Nov 3, 2019 at 5:29 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    love me some Tractor Supply. My box is from there and it didn’t cost me an arm and a leg
    TheFreshMouse likes this.
  14. Nov 3, 2019 at 5:38 AM
    bfd300
    bfd300 New Member
    I built a box 1x1ft and used the side rails to hang it
  15. Nov 3, 2019 at 4:23 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    My highly technical, temporary solution, until I get a Decked system.
    DECKEDUSA, jewsNbrews and YardBird like this.
