2002 4x4 SR5 Check Engine Light (CEL) P0300, 0301, 0308
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Nov 2, 2019.
  1. Nov 2, 2019 at 7:28 PM
    Peterv
    Peterv [OP] New Member
    Pete
    I thought I would share this experience I had with these codes. With the P300 code, it is a random misfire, and the 301 and 308 were specific cylinders, 1 and 8.
    Started with the fuel filter which seemed like the cheapest and most likely culprit, didn't work.
    I then checked the spark plugs and they looked a little worn, so replaced all of those, then also noticed a cracked vacuum hose, and replaced the PCV valve, which originally other posts seemed to say that there was an EGR valve, which my truck did not have. These things fixed it. Not
    bad for less than $100. YMMV
  2. Nov 2, 2019 at 7:30 PM
    Cheap fix for sure. Glad you got the problem solved.
  3. Nov 2, 2019 at 7:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'd call it an inexpensive fix. :thumbsup:
  4. Nov 3, 2019 at 6:40 AM
    Professional Hand Model
    Fred
    Hand Protectors
    How’d that PCV valve cover chamber look when you took it out? Mine was gunked! Glad you solved your problem and thanks for the follow up.
  5. Nov 3, 2019 at 8:18 AM
    Peterv
    Pete
    Hmm, I just changed the valve, didn't poke around inside the cover. Maybe I should?
  6. Nov 3, 2019 at 8:26 AM
    Fred
    Hand Protectors
    Ye mate. Only reason I saw mine all gunky was because I was doing the VC gaskets and had the covers off. That PCV grommet was toast and fell in. Looked in the hole and thick oil paste! Blasted it with Cleaner.
    I think if I was NOT doing the VC gaskets and my port chamber was clogged I’d try to scoop out as much as possible (difficult) using a popsicle stick. Then slowly over the course of a few weeks on a daily basis put a few drops of your motor oil or a quick 1/2 second blast of PB Penetrator in that port to dissolve it slowly back down into the valve chamber oil and circulated into the oil filter.
