Turn signal issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Rc358, Nov 2, 2019.
  1. Nov 2, 2019 at 6:48 PM
    Rc358
    Rc358 [OP] New Member
    Robby
    2008 Toyota Tundra Crew Cab 4x2
    Recently I’ve had an issue with my passenger side blinker staying on continuously while driving. It went away for quite a while but came back recently and will not turn off so I’ve had to pull the fuse and use hand turn signals while driving which sucks.
    Any ideas as to what might be causing this issue? I’ve check bulb, fuse and all are good.
    Any advise would greatly appreciated!
    2008 Toyota Tundra
  2. Nov 2, 2019 at 6:56 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Just put on a bmw badge and nobody will realize that they don’t work! Lol sorry. I don’t have a real answer, but I’m sure someone will come along who does.
  3. Nov 2, 2019 at 6:59 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Have you checked the flasher relay?
  4. Nov 2, 2019 at 7:00 PM
    Rc358
    Robby
    I have not. I’m not sure exactly where that is located? Any help?
  5. Nov 2, 2019 at 7:01 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I think it's in the driver's side kick panel. Remove the panel and turn on your flashers and you'll hear it.
  6. Nov 2, 2019 at 7:02 PM
    Rc358
    Robby
    Thanks. I’ll check it out and post my findings.
    TheBeast likes this.
