New to 4x4
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mamba, Nov 2, 2019.
  1. Nov 2, 2019 at 10:00 AM
    Mamba
    Mamba [OP] New Member
    Manny
    2020 Tundra Limited 4x4
    None
    Guys quick question I have looked at my manual and can’t seem to find the answer. How fast can you drive in 4x4 hi? Truck is a 1794 2020 thank you
  2. Nov 2, 2019 at 10:14 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    It's certainly in the Owner's Manual. My 2010 tells me 55 mph in 4 hi. THE vey best thing you can do ( and rare) is to read through that manual!:thumbsup: Seems like Owner's Manuals are like Sequential Shifters, Hazard Flashers and Park Lamps, "there" but seldom used!:D
    Rider0120 likes this.
  3. Nov 2, 2019 at 10:25 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    The previous answer is incorrect. You cannot SHIFT into 4x4 over 55-60 mph, but there certainly is no speed limit in 4x4. My supercharged truck routinely hit 120 mph in 4x4 before I converted it to AWD. Mechanically, the transfer case doesn’t care what speed you are going, as long as it is more or less in a straight line.
  4. Nov 2, 2019 at 10:25 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    never shift into 4 hi above 55 mph and never on dry pavement unless in a straight line. It’s not an AWD system and using 4wd in conditions that do not allow the front wheels to slip when turning will cause binding and possible axle and differential failure.
    ViktorG likes this.
  5. Nov 2, 2019 at 10:26 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    2 different things, shifting into 4x..... I believe the driver visor has that info. And, how fast you can actually drive in 4x. Not sure about the 2nd part but the computer seemed to limit me to about 95 mph..... (offroad flat lake bed where it was safe) then and add about 11% for my 37" tires so about 105 mph. BTW, I highly discourage this type of truck abuse.:p
  6. Nov 2, 2019 at 10:35 AM
    CMB
    CMB New Member
    Cecil County MD.
    The question was "how fast can you DRIVE in 4 wheel drive" NOTHING about SHIFTING into 4 Wheel Drive.
  7. Nov 2, 2019 at 10:38 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The ANSWER was "no speed limit in 4x4" -_- Literally says that in the quoted post.
    ViktorG and Cthulhu like this.
  8. Nov 2, 2019 at 10:46 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    ViktorG likes this.
  9. Nov 2, 2019 at 11:08 AM
    ViktorG
    Viktor
    Calgary, Canada
    That is the question I answered my good sir.
    The owners manual only mentions that the truck will not let you shift into 4x4 over 55mph.
    The manual states nothing about how fast you can drive in 4x4.
    You can drive in 4x4 up to the governed speed limit (110 mph in a NA truck, 125 mph in a TRD flashed supercharged truck or 130mph+ in a truck with speed limiter removed).
    From a technical standpoint, there is not much difference in 2WD vs 4x4.
    The front axles always rotate in 2WD, the transfer case internals always rotate in 2WD and pass the power through to the rear driveshaft.
    The only thing that changes in 4x4 is your front driveshaft and diff get connected to that equation, and there is absolutely nothing stopping them from rotating over the 55mph speed.
    If you can provide a picture of the page in the owners manual that says anything about the max speed you can drive in 4x4 I will apologize and admit I was wrong all these years. ;)
  10. Nov 2, 2019 at 12:01 PM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    You can actually shift into 4x4 while moving? He never knew that I always put it in park or neutral before going into 4wheel. Cool.
    ViktorG likes this.
  11. Nov 2, 2019 at 12:06 PM
    4Hi....yes. Do not shift into 4Lo while moving unless you like bad sounding grinding noises....
  12. Nov 2, 2019 at 12:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. Been that way a LONG time. My 1997 T100 four wheel drive allows on-the-fly-4-by (hi) up to 55 mph.
    reelcracker[QUOTED] likes this.
  13. Nov 2, 2019 at 1:01 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I'm sure going high speeds will increase tranny temps quite a bit. Especially the 2019-2020 tundras without the external cooler.
  14. Nov 2, 2019 at 2:02 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Can confirm this. My SC Tundra has gone same speed in 4 hi. Just refuse to say where that was, and if questioned, I will deny it. :spy:
  15. Nov 2, 2019 at 2:29 PM
    CMB
    CMB New Member
    Cecil County MD.
    No need for that Viktor, I was wrong, you Sir, have my apology. I miss-read the wordage in my Manual. Not to worry though, I've been Married for 46 years, so I'm used to being wrong most of the time!:facepalm::D
  16. Nov 2, 2019 at 3:10 PM
    Mamba
    Manny
    None
    Thank you guys so in short no speed limit on 4x4 hi correct. I read that in the manual you have to be below 65 or so don’t recall exactly but once engaged no speed limit.
    ViktorG likes this.
  17. Nov 2, 2019 at 7:17 PM
    ViktorG
    Viktor
    Calgary, Canada
    lol, all good man!
    I’ve only been with my wife 17 years, but I’m also quite used to being wrong... :)
