installing techstream
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Apr 18, 2018.
  1. Apr 18, 2018 at 3:24 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    has anyone had trouble installing teckstream software
  2. Apr 18, 2018 at 3:32 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Short answer .....Yes.
    I finally got it to take....after YouTube vids and reading the help answers here on this forum.
    Hopefully some of the more tech savvy will chime in.
  3. Apr 18, 2018 at 4:35 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Sub’d to learn.
  4. Apr 18, 2018 at 4:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No problems. But I bought the overpriced one that works with 32 bits for $50.
    831Tun and Black Wolf like this.
  5. Apr 18, 2018 at 7:51 PM
    kcaustin66
    kevin
    i downloaded it off of this site same ver. as the one I bought, but I need a key and ( I got a key that works) but no user name and password.
  6. Apr 18, 2018 at 7:56 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    The problem usually lies with the replacement of the mainmenu.exe file. The download will usually contain a mainmenu.exe file that is separate in the folder. You have to run the install as normal, then take the mainmenu.exe file that was separate, and copy/paste it and replace the mainmenu.exe file that the installer placed on your PC in the program files folder where the install is located.
  7. Apr 18, 2018 at 8:00 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    Mine installed/works fine. 64bit version 13.00.022 in windows 10.
    ToyotaDreaming likes this.
  8. Apr 18, 2018 at 8:08 PM
    kcaustin66
    kevin
    did yours ask for a key
  9. Apr 19, 2018 at 7:52 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    yes, and techstream.exe and mainmenu.exe were swapped out
  10. Oct 30, 2019 at 9:45 AM
    Obtunded
    Obtunded New Member
    San Antonio
    2016 Tundra CrewMax XPS-X 4x4
    Carbon fiber dash, leather seats
    I've been having trouble for days. It's loaded on a 64 bit but it seems like it loaded. It asks for the key for software registration then a user ID and password. I'm frustrated
  11. Oct 30, 2019 at 10:54 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Did you get this version from Amazon? Or, other?
  12. Oct 30, 2019 at 4:33 PM
    Obtunded
    Obtunded New Member
    San Antonio
    Yes. 39.99. Did you have the same problem
  13. Oct 30, 2019 at 7:51 PM
    JohnLakeman
    Uh, no...I was actually asking @scotch where he got the Techstream version that worked.
    Most of the boot-leg versions for sale will have some means of technical support...Did you try that?
  14. Nov 2, 2019 at 7:00 AM
    Obtunded
    Obtunded New Member
    San Antonio
    not yet. i had a feeling once i got the disc and it looked like a generic disc. it got great ratings on Amazon. im sitting right now attempting to reinstall with all the advice from all the great tundra viewers
