14 tundra LED headlight bulbs???
Discussion in 'Lighting' started by Tommy D38, Oct 30, 2019.
  1. Oct 30, 2019 at 3:18 PM
    Tommy D38
    Tommy D38 [OP] New Member
    Tom
    14 Tundra SR5 crewmax TRD
    305's ; Linex bedliner ; Lund side tubes ; Lund fender flares ; 18" Monster 2 wheels
    So I looked on YouTube to find some advice on how to change out my 14 TRD SR5 crewmax headlight bulbs to LED from stock halogen. Looks pretty dag-gum intensive for bulb swap.
    Do I really need to remove my grill and lower front 1/4 panels?
    Have any of you done this and IS IT WORTH IT?
    For the cost of the bulbs it’s worth it, just a lotta work and taking things apart!
  2. Oct 30, 2019 at 3:28 PM
    AZBoatHauler
    So.Arizona
    Everything I've read says do NOT put LEDs in a housing designed for halogen. The reflected scattered light will be blinding to oncoming vehicles and useless to the driver. Best bet is to retrofit projectors or buy the 2018+ Toyota LEDs and a harness to make them work.
    GODZILLA likes this.
  3. Oct 30, 2019 at 3:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This^
  4. Nov 2, 2019 at 1:39 AM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    That hasn’t been my experience with the Beamtechs I installed. Big plus is they are plug ‘n play. Even if they burned out tomorrow I could buy 8-15 more sets for the price of 1 pair of the newer OEM headlights or the zooty brand name lights.
    The LED headlight bulbs if they are in the proper orientation, have a distinct cutoff. If it’s too high just lower it with the in-dash motor dial. I haven’t been flashed yet by other drivers.
    Paying about $200++++ for headlights is just plain nuts IMO. I paid $40 from Amazon. Mo money for gas!
    OP, pulling the grill and small panel is no big deal. Couple of plastic push “pins” that come out really easy and 4 10mm “bolts”. (More like screws, I used my cordless drill)
    It’s a little pucker when you pull the tabs that are on the bottom 2 sides but that’s only because it sounds like a plastic SNAP.
    Just look at headlight revolution vids and do it to it. They show the correct way to pull everything and it takes *maybe* 20 minutes.
  5. Nov 2, 2019 at 3:25 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I installed Hikari Ultra Led and the beam pattern seems fine with a sharp cut-off line. I don't get flashed by other drivers.
    I have 2010 and when I installed Philips Crystal Vision bulbs years ago (These white halogen bulbs seem to last around 2 years for my use), I didn't have to take the headlights off. With LED bulbs with protruding back, I found it necessary to take the headlights off. It was a lot easier than I thought. I would think 3rd gen Tundras are similar.
    (From what I read, LED bulbs used to be terrible. Nowadays, they are designed so that they mimic the stock bulbs by putting the LEDs at the same location as the filament's location.)
    Glockmeister likes this.
