2005 Sequoia Headlight Assembly Replacement....
Discussion in '1st Gen Tundras (2000-2006)' started by theplanesaidso, Oct 31, 2019.
  1. Oct 31, 2019 at 11:25 AM
    theplanesaidso
    theplanesaidso [OP] New Member
    2005 Seq. 4x4 SR5
    My 15 yr. old factory headlight assemblies are fogged, yellowed, and one side-marker full of water, so figured it's time for a replacement. I order these off Amazon following good reviews: https://www.amazon.com/gp/product/B079DJRW6W/ref=ppx_yo_dt_b_asin_title_o03_s02?ie=UTF8&psc=1 COMPLETE JUNK! There is absolutely no horizontal adjustment possible despite their being a screw. I was able to adjust vertically okay, but not the least horizontally so I have a narrow 6ft. wide beam right in front of the truck, then a dark shadow about 4ft. to the sides of that and a little light after, makes turns pretty difficult! So, wondering if anybody here recommends aftermarket assemblies that actually work and can adjust both ways?
    Thanks!
  2. Oct 31, 2019 at 11:58 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  3. Oct 31, 2019 at 3:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Akkon has some nice assys.
    First set (2 headlamps and 2 sidemarkers): One of their side markers leaked after a month. Went through return process and they sent a whole new set!
    Kept the box and stashed away the ‘leaky’ one (which will get some caulking) with the new others. Complete new back up set for the future!
    So far so good with about a year on these. Clear and clean. Nice reflector action. Good adjustments, as well. 2002 Tundra.
  4. Oct 31, 2019 at 3:23 PM
    theplanesaidso
  5. Oct 31, 2019 at 3:31 PM
    Fred
    Hand Protectors
  6. Oct 31, 2019 at 3:44 PM
    theplanesaidso
    Okay, gonna try the Akkons, thanks!
  7. Nov 1, 2019 at 4:37 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    In my experience all the aftermarket headlights are trash. Their reflectors are inferior and aligning them is a pain. Hell spent $150 on mine and they are still crap. Just like OEM my ass. I'll be upgrading them with retrofitted HID projectors in the future.
  8. Nov 1, 2019 at 7:07 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I ordered these and were pretty pleased with them. The headlights fit great, and I didn't need to align them (though I should probably tweak them down a tad due to my lift). The corners site a little proud of the headlight but you can't really see it...you have to feel it. I've had them for about 18 months and they seem to be holding up just fine. Came in an Angel Eyes branded box from Taiwan. Happy with the light output too...much better than my stockers with hazed housings.
    https://www.amazon.com/gp/product/B0791J85WV/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Note: I had initially planned to just polish my OEMs, but one headlight housing was broken, and one corner light was broken. I was even going to find non-broken items from the parts yard and clean them up, but they are few and far between around me. I thought these would be a good budget try.
  9. Nov 1, 2019 at 7:22 AM
    Fred
    Hand Protectors
    Yeah. I polished mine about 8 years ago with a $35 3M Polish Kit. Looked much better, but not new and only lasted about 6 months. Second polishing looked like butt. Bought some Mainland China mades ($50 with bulbs!) which lasted till this past year.
    The early 1st Gens headlights combos are pretty inexpensive (non-OEM). Mine were about $115 from Tiawan and these Akkons side by side with the Mainlanders seem much better made. Heavier and more precise components fab.
    OEM is $450? I’m sure they are made well, but is the price paid worth it if these Akkons are doing their job?
    SC T100[QUOTED] likes this.
  10. Nov 1, 2019 at 9:21 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    That's what I picked up a few weeks back for my 06. Not exactly thrilled with the adjustment system. I sit and turn the adjusters for 10 minutes and can't tell if anything is moving. My old headlights were broken so I had no choice but to replace but I'm not sure I'll be keeping the akkons or akkrons or whatever they are.
  11. Nov 1, 2019 at 10:17 AM
    Fred
    Hand Protectors
    I had that adjustment problem myself until I found out about the long phillips screw driver down the top adjust hole to adjust that cam trick. Prior, I was using two 10mm wrenches on the backside/frontside of nut and it took forever and was so slow it was difficult to tell if an adjustment was being made. It was a stupid hand model mistake, but thanks to everyone here to help me figure it out.
  12. Nov 1, 2019 at 12:50 PM
    KarmaKannon
    Utah
    Some junk
    I'll be a hand model if I keep trying to adjust these headlights with my long phillips screwdriver. Honestly I turn one side for 5 minutes solid and maybe it moves a little but not much. I'm thinking that much turning should be the difference between the sky and pointing 4' in front of the bumper.
  13. Nov 2, 2019 at 2:48 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I think.your adjustment knob is broken
    KarmaKannon[QUOTED] likes this.
  14. Nov 5, 2019 at 3:42 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    For 1st gen Tundra headlights these are different, and can't imagine what they would look like on 1st gen trks. However, on vehicles from different mfgr's I've seen them and they're not bad looking at all. If your not familiar with the other mfgr's vehicles these aftermarket headlights are on you wont know the year it is.
    https://www.autoanything.com/lights/spyder-headlights
