  1. Oct 30, 2019 at 11:27 AM
    Anyone heard from @Casper421 ? Did you survive Utah man?
  2. Oct 30, 2019 at 12:16 PM
    Thank you sir! Your next box of gloves are on me!
  3. Oct 30, 2019 at 2:38 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    For those of yall with SPC UCAs, how often do you grease the ball joints and how many pumps? I had not greased mine myself since last December when I installed them and gave em 10 pumps each. I just gave em 5 each. Last time I got my oil changed (it's almost time again) I asked em to grease everything but I highly doubt they did.
  4. Oct 30, 2019 at 3:55 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    7-12 pumps every oil change (10k for me}
  5. Oct 30, 2019 at 4:17 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Thanks. I'll give it another couple pumps when I change the oil in a few weeks I guess.
  6. Oct 30, 2019 at 4:20 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I received my double din radio and started to install then I hit a snag! The wiring harness I ordered does NOT match. I took a picture (attached). Anybody run into this and know what harness is the right one??
    The top two are the stock harness from the truck. The bottom one is the harness that I received. This is the standard harness I find all over when I google "2003 tundra radio harness". Any insight would be super appreciated!
    because_wumbo-truck likes this.
  7. Oct 30, 2019 at 4:26 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Oh boy I know those blues all too well my friend. I went thru 3 harnesses before I got it right. Looks like you might need the same one I did. Which is the amp bypass harness. It's super long and you'll have to run it from the radio to the amp under your passenger rear seat
    Be carefully where.you run this, as I managed to accidentally snag mine on the passenger kick panel and it shorted out and fried the amp on my touch screen. Had to buy another touch screen. :(
    bmf4069 likes this.
  8. Oct 30, 2019 at 4:28 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Dig a few months back in this thread to where wumbo and I were trying to diagnose his. That few days pretty much covers all of it.
  9. Oct 30, 2019 at 4:30 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Start around post 9695
  10. Oct 30, 2019 at 4:31 PM
    imDementeD
    Really appreciate that info! I didn't think I had an amp in this truck honestly. The system looked like the cheaper version but will go dig back to your experiences and send back this harness...
    I ALMOST took this to a shop to just do all the work but I thought it's just to easy to pay someone to do it.......and here we are....
  11. Oct 30, 2019 at 4:33 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Check under the rear pass seat inside the storage compartment for an amp or a black plastic thing hiding an amp behind it. We both have limiteds. Do you have the 6 disk changer?
  12. Oct 30, 2019 at 4:48 PM
    You just asked this question a month or two ago man. You losing it? ;)
    SPC says 5 pumps every oil change.
  13. Oct 30, 2019 at 4:49 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Lol I guess I am
    I finally remembered to top mine off this afternoon
  14. Oct 30, 2019 at 5:01 PM
    imDementeD
    Radio looks the same but I don't think I have a 6 disk..Haven't really gotten into the truck like that yet. Nothing in the storage area BUT I did notice that there was something that LOOKED like an amp in the dash. I just went out to grab a quick pic (don't judge the dust, idk what this truck was used for before me) and i also noticed that the harnesses that plug into the radio go directly into this box and I also just saw two plugs that go into the box. I am going to remove it it and see if the plugs that go into this "amp" match the harness I purchased. If so, I'll just rip this out?
  15. Oct 30, 2019 at 5:08 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    That's right, the older.models had the amp.in the dash. You're lucky. Yours will be easy once you get the right harness
  16. Oct 30, 2019 at 5:11 PM
    imDementeD
    Actually, because of your help and turning me onto the amp I found a blog (link below) and they said just remove the harness that goes into the amp and plug into the standard harness I purchased. Super easy!!
    https://caraudiotips.blogspot.com/2013/01/toyota-tundra-factory-amp-bypass.html
    I appreciate everyone's help on this and hopefully, if another harness issue arises, someone can benefit from this dialogue.
  17. Oct 30, 2019 at 5:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The regular radio plugs are on that one. Just unplug it and remove it if you wanted.
  18. Oct 30, 2019 at 5:21 PM
    imDementeD
    ^ yea I just went outside and ripped the amp out and sure enough, the harness fits!
  19. Oct 30, 2019 at 6:03 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Any progress on this? It got below 50 today for the first time and mine started singing like a bird.
  20. Oct 30, 2019 at 6:47 PM
    Never again! That fuel filter is the devil!
    BubbaW, NUDRAT and Darkness like this.
  21. Oct 30, 2019 at 10:43 PM
    empty_lord
    05 rollover special
    [​IMG] Well cut the headliner for the overhead... ain’t the prettiest cut ever... but you can’t see it. Now to do the secondary sun visor cuts..
    Can a anyone take their secondary visors off and shoot me a pic of the hole in the visor?
    (Access cab ones, not the double cabs, totally different)
    TX-TRD1stGEN and NUDRAT like this.
  22. Oct 31, 2019 at 12:33 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Open heart on my 2004 went well and she is now in Intensive care. She'll have to deal with our unexpected 38deg weather outside by herself. I have to take one for the team and manage the central heat.
    Overall I am very satisfied with the Service Rep who was a pleasure to work with and the Master Tech who performed the surgery. If ever in the Tuscumbia Al area, give Toyota of the Shoals a shout. Tell Kip(Service Rep)or Keith(Master Tech) that Bubba highly recommended them.
    Total Parts: $1330
    Total Labor: $1336
  23. Oct 31, 2019 at 12:36 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Dang that's high
    YardBird likes this.
  24. Oct 31, 2019 at 1:26 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    121 dollars for an idler!! Jeez
  25. Oct 31, 2019 at 1:47 PM
    Yeah. Holy shit. Bubba, you should have has us price check that man. That's insanely expensive.
    I'm very curious what a fuel system cleaning actually does. I paid for this on my old Corolla once and felt like I got hosed. Doesn't look like they even replaced the fuel filter.
  26. Oct 31, 2019 at 1:52 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Cool Springs:
    List Price: $121.39
    You Save: $38.34 (31.60% off)
    Sale Price: $83.05
    ToyotaPartsDeal
    Your Price: $86.12
    Retail Price: $121.39
    You Save: $35.27
    Having looked up most of the parts online before making final decision, I knew going in what their parts prices were versus what I could have paid by buying online from CoolSprings, ToyotaPartsDeal, etc... At the end of the day it was a personal decision and what is not shown in those figures is the $450 discount they gave me which somewhat made up for the somewhat higher prices in parts compared to online. Only thing I could then question is the Labor which I won't do because all that they did was reasonable figures as far as I am concerned. Having been raised around home construction with my Dad(God rest his Soul), if a person performs quality work, I'm prepared to pay their rates if it's within reason. Keith gave me quality work and I am very satisifed….YMMV in your projects !
  27. Oct 31, 2019 at 2:08 PM
    If you're fine with the prices that's all that matters. The truck will run great when you get it back. Good for another 90k!
    TX-TRD1stGEN and BubbaW like this.
  28. Oct 31, 2019 at 2:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    The $450 discount helped me be fine knowing they can not compete with prices CoolSprings or others offer online. In fact when I was in the Nashville area, I visited a Toyota Dealers Parts Dept, gave them a list for a quote. Needless to say their counter prices were the same or similar to Toyota of Shoals counter but their online prices were indeed discounted compared to their counter prices.
    Yes, the truck runs as great as it did when I dropped it off. He was actually impressed with the toughness of the engine and could tell it had been well maintained. IF I was 20, maybe even 10 years younger when I was always doing my own things, the price out of pocket would have been drastically different. I'll still be doing other things in coming months....brakes, fluids, valve caskets :) and a number of other things. Age catches up with all of us but they haven't thrown dirt on me just yet :)
    NUDRAT and bmf4069 like this.
  29. Oct 31, 2019 at 3:44 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Checked the oil level which was good. Coolant good! Filled up washer fluid reservoir.
    Lubed up the front hood closer shafts with some PB Blaster with Lithium. Speaking of these, does anyone remember the action on these when they were new? I seem to remember slightly raising the hood to open and then it raised up on its own. Now I need to get mine more than halfway and then it raises slowly on its own.
    The closers are expensive and not something thats a big deal as they are still working ok/decently. Paid good money a few years back for new closers replacements on my Aluminum Side Boxes. Went with a heavier duty type (rated in pounds) and they performed nicely.
    Anyone have a quick cheap fix other than a broom stick prop?
  30. Oct 31, 2019 at 4:29 PM
    empty_lord
    05 rollover special
    [​IMG] Well newer radios work. But uh. This one doesn’t fit
    So the real question is, do I swap in a newer oem touch screen and enjoy working factory functions like the dimmer and a much cleaner install. Or do I go aftermarket and enjoy all the bells and whistles. Pricing seems about on equal feature for feature. But no car play units that’ll fit the factory hole in the dash
