Camp Chef Pro pellet smoker
Discussion in 'Off-Topic Discussion' started by Rica25, Oct 27, 2019.
  1. Oct 27, 2019 at 7:33 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Does anyone have this smoker? Or has anyone purchased a smoker under 500 bucks that you would really recommend
  2. Oct 27, 2019 at 7:57 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got an electric, master chef I think. It was under $150 I think. Love it. We use it all the time
    Rica25[OP] likes this.
  3. Oct 27, 2019 at 7:59 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Hows the taste with electric? I like the idea of an electric smoker to use as an oven during the summer to keep house cooler.
    But man i love wood smoke flavor!
  4. Oct 27, 2019 at 8:00 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Camp chef makes good quality products. I have one of their smokers and camp stoves.
    Rica25[OP] and RLHULK like this.
  5. Oct 27, 2019 at 8:09 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    You still use wood chips w electric. Just very convenient w setting temp and time. There’s a little tray you pull out, put wood chips in and then they go right over heating element.
    Rica25[OP] and Hbjeff like this.
  6. Oct 27, 2019 at 1:29 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    The taste off an electric is the same. The only difference I've noticed is that you don't get the smoke ring. But that doesn't add flavor, just a nice appearance. I had a Masterbuilt for about 10 years until it developed a ground fault. It was very good. My new one I'm not as happy with. I have to set it 30-50 degrees higher than the desired temperature. It maintains temperature well, about +/- 5 degrees, but I have to get it dialed in when I load it.
    I've also been told that pellet smokers produce a lighter smoke flavor, but I can't verify that.
    Pudge, BravoDeltaRomeo and Rica25[OP] like this.
  7. Oct 27, 2019 at 1:31 PM
    JMB
    Chesapeake, VA
    Masterbuilt max temp is 275, not good as an oven.
    Pudge and Rica25[OP] like this.
  8. Oct 29, 2019 at 9:02 PM
    Rica25
    Ricardo
    Tulare
    So I think I have decided to purchase the Camp chef pellet smoker PRO model
    .......since I cant afford a Tundra PRO but I can afford a Camp chef PRO:rofl:
  9. Oct 29, 2019 at 10:17 PM
    waj30
    waj30 New Member
    Wayne
    Eastern Kansas
    2016 Toyota Tundra Crew Max 4X4 TRD Off Road
    I have the Camp Chef Woodwind.
    Pudge, Flyinryank, Hammerdog and 5 others like this.
  10. Oct 30, 2019 at 6:02 AM
    Rica25
    Ricardo
    Tulare
    How do you like it?
  11. Oct 30, 2019 at 6:45 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I have a Z Grills pellet smoker. Same brand that makes Traeger but half the cost.
    Hbjeff likes this.
  12. Oct 30, 2019 at 7:15 AM
    Jas4tundra
    Jas4tundra New Member
    Jasmeet
    2019 Tundra limited white
    Stock
    Sams club has new masterbuilt pellet grill for 299 check that one out
  13. Oct 30, 2019 at 7:33 AM
    waj30
    waj30 New Member
    Wayne
    Eastern Kansas
    If I had it to do over again I'd buy a bigger one. Other than that its been a good one. Had it for three years so far.
    Rica25[QUOTED][OP] likes this.
  14. Oct 30, 2019 at 8:27 AM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    I got my green mountian grill Daniel Boone for around $450. They have deals around any bigger holiday. Never had any issues with it so far in 3 years.
  15. Oct 30, 2019 at 8:37 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    There is a much steeper learning curve then the set it and forget it, big box stores type smokers everyone is using nowadays, but this was $300cad, used, farmer built, and comparable to $1000 smokers in terms of build quality.
    Check your local used sites. Lots of people buy smokers and then realize they don't use them enough to warrant the footprint it takes up on their deck.
    Plus, this is a real wood smoker, no charcoal, no propane, no electricity, no pellets...all wood and all smoke.
    Rica25[QUOTED][OP] and Hbjeff like this.
  16. Oct 30, 2019 at 9:43 AM
    Rica25
    Ricardo
    Tulare
    I have a Wber smokey mountain already and love it just sometimes I dont want to sit there and watch it to much so I wanted the pellet for a little less work
  17. Oct 30, 2019 at 9:53 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I've had a Camp Chef DLX pellet grill for about 5 years. I like it to a certain point. I've had it flame out on me several times even though I'm quite diligent about keeping chamber and temp probe clean. On the smoke settings, the low smoke in particular, it won't hold the temp for shit. The low smoke is supposed to hold the temp at 165 degrees. For me it goes as low as 140 degrees and as high as 190. That's a 50 degree swing and far too much to do any sort of serious smoking. I mainly use it for adding a little smoke flavor to steak and burgers so I usually put it on low smoke for 30 minutes then ramp the heat up.
  18. Oct 30, 2019 at 9:56 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yup, they all serve a purpose and it's nice to have a few if possible. It took me years to build up the confidence to take the plunge on a dedicated stick burner, then a few more years finding one that didn't break the bank and meet my expectations for build quality
    A WSM has long been on my want list.
  19. Oct 30, 2019 at 10:05 AM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Use a Traeger year around here. Its our second unit and is hard to mess up a piece of meat on it. Think it was on sale at HD for around $600. But the next one will be a Green Mountain...
