  1. Oct 28, 2019 at 4:58 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Thank you. I cut the emblem using a Oscillation cutter with a straight carbide blade. I sprayed with cans and in this case doing the entire tailgate was best. I removed it and did the prep and spray on sawhorses. My side doink I tried the blend method due to wanting to keep it on a smaller scale and save my TRD sticker! Went through the learning curve and had to re-do. Anytime you paint its best to do the entire section.
    Anything is possible. Back in the day I’d have been a youtubes star, but Chris Fixx has stolen the limelight with his sexy hands.
    Here is the paint I used. Go to the site and plug in your info. Damn good match. Their clear coat is good, but not perfect. Thats magic mojo stuff to get it right.
  2. Oct 28, 2019 at 5:12 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Thanks for the follow up and adding clarity in such a clear, yet succinct, manner. Likewise, thanks for the link to the paint - far less expensive than what I've come up with previously.:thumbsup:
  3. Oct 28, 2019 at 5:20 PM
    Fred
    Hand Protectors
    That color match is very nice. I almost believe you could spray it and not even use a clear coat which would yield a nice Matte Finish. I leaning towards that route for the future.
    The problem I had was with the Bondo’d areas and the gray primer. I think spraying clear coat over the Bondo first would be better vs. using primer as the succeeding finish coat yields a better finish where I did an experiment. This is all lacquer spray so its quick dry and the spray tips on the cans are top notch.
    marbleville[QUOTED] likes this.
  4. Oct 28, 2019 at 6:36 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    how many cans of base and clear did you use?
    looks like it came out well nice job.
  5. Oct 29, 2019 at 4:41 AM
    Fred
    Hand Protectors
    One can base on the tail gate doing multiple light coats (10-15). One and a half cans clear coat multiple light coats (10-15).
    Filthyphil[QUOTED] likes this.
  6. Oct 29, 2019 at 12:34 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I just got back from a week long camping / fishing trip. Due to the different types of lakes we were going to. I needed to bring two boats. One for bigger Lakes and one for the lakes that are four wheel drive access only. This means I needed some sort of rack for the bed of my truck to put my small 10ft Jon Boat on. I'm not done with it yet but close enough to work for the trip. I made the whole thing out of Unistrut. It side lifts from the driver side to the passenger side allowing me access to the gear in my bed. I did order two 100 lb 35 inch gas strut lift assists but didn't receive it before I left for my trip. I bed lined the whole rack which I am not happy with the final product. I used Dupli-Color bed liner. I prepped according to what the can said. After a few days of use though the bed liner has started to peel off. I'm going to have to scrape the whole thing and reapply with something better. I found the Dupli-Color to be very brittle and not impact resistant at all. Does anybody have any suggestions on a better bed liner product? Here's what I came up with for the rack.20191028_172931.jpg 20191016_171515.jpg 2019-10-29 09.52.41.jpg 20191022_132238.jpg 20191023_102857.jpg
    onesojourner, MS22, SC T100 and 13 others like this.
  7. Oct 29, 2019 at 12:35 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Truck looks good.
    How much.lift is that?
    Brown Bear[QUOTED] likes this.
  8. Oct 29, 2019 at 12:43 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    6in rcd lift in the front, 4 in lift with custom leaf springs in the rear.
  9. Oct 29, 2019 at 1:25 PM
    marbleville
    Yep, last name too.
    State of Confusion
    @Brown Bear Any chance we could get a couple closeup pics of the attachments to the truck bed's upper railing - components/assembly? Any chance of you doing another thread with its design and construction laid out before us? [Not asking too much, am I?:rolleyes:]
    I don't currently have a need for such a rack as my boat is a pontoon, and easily disassembled, but...It would be nice to load the pontoon above my gear, and fully inflated, when hopping between points, lakes/camping spots, as the fishing dictates.:transformer:
    NUDRAT and Brown Bear like this.
  10. Oct 29, 2019 at 2:08 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    I will do a write-up on the rack once I get time to finish rebed line in it and putting on the gas Pistons. I will try to get some time tonight to take some pictures for you though.
  11. Oct 29, 2019 at 4:45 PM
    Unistrut is usually galvanized or has some weird coating on it. Would that affect the bed liner?
  12. Oct 29, 2019 at 7:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got some thick soft foam pads from shipping shit at work.. seems like it would be a good noise killer in the cabin, any spots y’all can think of to put some of it?
  13. Oct 29, 2019 at 7:35 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Behind the Speedo,. Radio, glove box
  14. Oct 29, 2019 at 7:36 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
  15. Oct 29, 2019 at 8:35 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Over your ears :D
  16. Oct 29, 2019 at 8:59 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    I sanded it pretty good with 80 grit. Sprayed it off with an air compressor. Then cleaned it with alcohol. I would think the sanding would have made it bond.
  17. Oct 29, 2019 at 9:02 PM
    antwon412
    antwon412 New Member
    2006 CC SR5
    Anyone ever mounted off road driving lights directly to the bumper? I wouldn’t mind doing that instead of using a bull bar
  18. Oct 29, 2019 at 11:18 PM
    empty_lord
    05 rollover special
    you sir are living in the year 2119. lol
  19. Oct 30, 2019 at 8:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    hollering uncle....where the heck is the fuel filter on a 2004 DC 4.7 ?
  20. Oct 30, 2019 at 8:33 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Should be under the drivers door along the frame rail.
    BubbaW[QUOTED] likes this.
  21. Oct 30, 2019 at 9:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks fester....found another good "Timmy the Toolman" video while searching. Found him to be somewhat wordy but explains it well as he goes. Overall he's one of my goto sources along with Chris Fixx for videos.
    https://www.youtube.com/watch?v=vdDhXZIs6Lo
    because_wumbo-truck likes this.
  22. Oct 30, 2019 at 9:31 AM
    @bmf4069 said he'll help you replace that fuel filter. He loves doing it.
    :stirthepot:
  23. Oct 30, 2019 at 9:40 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    So for anyone wondering about progressive AAL, I always recommend Wheelers Off Road over all others and here's why.
    speedtre and TX-TRD1stGEN like this.
  24. Oct 30, 2019 at 9:45 AM
    It would be interesting to measure the Icon and Wheelers to see what the difference is.
  25. Oct 30, 2019 at 9:48 AM
    Fred
    Hand Protectors
    Galvanized is a difficult surface to make accept a coating. Ospho will help pre-treat the metal by changing the composition. After following the instructions, I’ve had great success with the Rustoleum Bedliner so that is one recommendation. Even a regular enamel coating will work post Ospho.
    Two things you are up against right now are getting the existing failing bedliner coating off and most critical is the scraping of your boat on the painted metal bracket. Might want to consider screwing some type of plastic/hard composite trim at the contact points.
  26. Oct 30, 2019 at 9:49 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I think new leafs is certainly going to give.you the best results but be the most expensive as.well. however I think an economic option in your case would be to swap the icon for the wheelers and throw the overload back in when you do. Then sell the icon set. Probably best to sell it to a taco owner as they are lighter. Just food for thought.
  27. Oct 30, 2019 at 9:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    :D ain't pulling the wool over my eyes....recently read his valve cover gasket replacement thread and I'm sure he'd disagree !
  28. Oct 30, 2019 at 10:08 AM
    Fred
    Hand Protectors
    @FrenchToasty
    Your requested fuel injector instructions. Most important piece of advice is to not lose those banjo fitting washers (17mm nut).
  29. Oct 30, 2019 at 10:29 AM
    I'm just going to wait and eventually get new leaf packs. I feel like at a certain point the AAL is just a band-aid(even the wheelers). My truck will be 20 years old before I know it so that's a good run for factory leaf packs. But in hindsight, I should have tried the Wheeler's. I just thought it made sense to stick with ICON since I have all their other products and they generally have a good reputation.
  30. Oct 30, 2019 at 10:47 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I think that's a good choice. I also think the icon AAL was designed for a Tacoma but fits Tundra, similar to the other AALs. So maybe icon didn't account for the extra weight of our trucks. Not sure.
