Transfer case info.
Discussion in '2.5 Gen Tundras (2014-2021)' started by hagrid, Oct 29, 2019.
Who can answer me my questions three? A pole.
  1. I can! Pick me, Spraynard!
    50.0%
  2. Me me me!! I know the answer!!
    100.0%
Multiple votes are allowed.
  1. Oct 29, 2019 at 1:56 PM
    hagrid
    hagrid [OP] The most diverse of Diversity Hires!
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I seek it, for reasons I shall enumerate presently.
  2. Oct 29, 2019 at 1:58 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I wish to know what model transfer case is in my Tundroid. A simple Google search was fraught with dealer invites and failed to yield ore.
  3. Oct 29, 2019 at 4:01 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s not the same as the 07 through 13. This unit is a Borg Warner.
    Transfer Case
    The Tundra gets a new T-case for 2014. It’s manufactured by BorgWarner and it has cut metal gears that are heat-treated for strength. The output shafts are hardened steel. Toyota points out that there are no powdered metal gears or shafts in this transfer case. The new case is said to have larger bearings than its predecessor and it was designed to engage faster in 4-Hi. The new T-case has a low range ratio of 2.64:1. We encountered no problems engaging or switching between settings on the T-case. Also new is a larger-diameter rear driveshaft.
    http://www.fourwheeler.com/vehicle-reviews/1401-2014-toyota-tundra-the-third-generation-first-drive/
    You can also just tell by the use of pipe plugs for the fill and drain plugs. Previously they used a bolt of some type.
    https://www.tundras.com/threads/3rd-gen-2014-diy-transfer-case-oil-change.53452/#post-1413493
    hagrid[OP] and Pinay like this.
  4. Oct 29, 2019 at 5:39 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I endeavor to determine if the front drive shaft turns at the same rate as the rear shaft.
    Also, is it chain or gear drive.
    15whtrd likes this.
  5. Oct 29, 2019 at 8:04 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    15whtrd likes this.
  6. Oct 29, 2019 at 8:15 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Chain drive, and it's the Sequoia that gets an AWD transfer case.
    15whtrd likes this.
