Sr5 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by MEGALODON18, Oct 29, 2019.
  1. Oct 29, 2019 at 6:43 PM
    MEGALODON18
    MEGALODON18 [OP] New Member
    Kyle
    2018 tundra crewmax 4x4 5.7 v8 MGM
    None yet.
    any have a 2014 and up tundra crewmax sr5 trim. Just sr5 trim with just bigger tires and stock suspension. Please pics be great. I’m just wanting to see what it looks like before I get new tires.
  2. Oct 29, 2019 at 6:47 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    Tons and tons of threads with this information. 2014-2020 are practically the same. I’m sure others will link to the threads for you..
  3. Oct 29, 2019 at 6:50 PM
    MEGALODON18
    Kyle
    None yet.
    Copy that. Thanks
  4. Oct 29, 2019 at 6:50 PM
    18" TRD Off Road Wheels
    Look up CementTurdOffRoad. He put different wheels on, but did a 275/70R18 on stock suspension. It sold me on that size as well. You'll have to find some of his older picks, because he recently upgraded the suspension a bit.
  5. Oct 29, 2019 at 6:53 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
  6. Oct 29, 2019 at 6:57 PM
    fundra_goes_west
    Evan
    2022 SQ8
    I’ll be going to 35’s though and a new suspension. To me they look a bit too small even on stock suspension. (That’s what she said)
  7. Oct 29, 2019 at 6:59 PM
    MEGALODON18
    Kyle
    None yet.
    Ya I have a 2018 tundra. Will I have a problem lifting it and getting it aligned right ? If I run 6112 at 1.9 setting with driver side shim and 5160 in the rear with +2 shackle and 285/70/18 nitto ridge grappler and 18 inch wheel with +25 offset ?
  8. Oct 29, 2019 at 7:00 PM
    MEGALODON18
    Kyle
    None yet.
    Are these trucks difficult to align properly
  9. Oct 29, 2019 at 7:01 PM
    These trucks are all pretty individual. Some guys struggle to get them aligned, others don't. IIRC it's usually been a tire issue, though.
  10. Oct 29, 2019 at 7:03 PM
    MEGALODON18
    Kyle
    None yet.
    I’m just stuck and worried about if I do lift my truck. I’ll have a problem with them alignment my truck. I don’t wanna spend $4,000 and then my truck is messed up.
  11. Oct 29, 2019 at 7:06 PM
    I hear you. I would advise you to talk to some locals that have lifted trucks, and ask where they had it done. Get a feel for the local "experts" and ask their advice. I assume that you will have it aligned elsewhere, so raise these concerns with any place you would consider having the alignment done.
  12. Oct 29, 2019 at 7:07 PM
    fundra_goes_west
    Evan
    2022 SQ8
    All the stuff you are describing is bolt on. I would read through as many threads here as possible searching your setup. I’m new to this and had the same worries. At the end of the day, do what you can afford and think you will make you happy. Worst case scenario you have to return it to stock and sell the gear second hand at a loss. If you can’t afford that (no offense) don’t do it. That’s just the way I think about it, I’m no expert
    GODZILLA likes this.
  13. Oct 29, 2019 at 7:13 PM
    MEGALODON18
    Kyle
    None yet.
    Thanks for the info. I’ve always been the guy that lifts my trucks. And I heard these trucks are finicky to lift. And now I’m just stuck between if I should or not.
    fundra_goes_west likes this.
  14. Oct 29, 2019 at 7:26 PM
    Caution is good, paralysis is not. Go check out some of the builds on this forum. I don't think lifts would be as popular if the trucks were prone to issues when lifted. Plus, you don't have the TSS to fight with on a 2018. You're money ahead at that point. lol
  15. Oct 29, 2019 at 7:31 PM
    MEGALODON18
    Kyle
    None yet.
    Yes I have the tss Toyota safety sense. I have all that. So that’s not a good.
  16. Oct 29, 2019 at 7:33 PM
    MEGALODON18
    Kyle
    None yet.
    I have researched for months and months. Knowing me I’ll have the issue when I do lift my truck. So I’m just thinking about what I should do. I don’t want a stock struck..
  17. Oct 29, 2019 at 7:37 PM
    Are you in a rush for this? If not, start with a set of bigger tires, like the 275/70R18 and see how you like it. I originally thought I was going to want a lift, but since seeing @CementTurdOffRoad truck I have changed my mind. Just the bigger tires will get me a wee bit more clearance, and save loads of money. Try it out. If after some time you don't think it's enough, move toward the lift. You're not on anyone's schedule but your own.
  18. Oct 29, 2019 at 7:40 PM
    MEGALODON18
    Kyle
    None yet.
    I know. But I see all these guys on the tundra forum with 2018 and 2019 tundras with 2 inch of lift and more with no problems. So if I do this I think I’ll be good to go. Plus last month I just had my tss recall fixed and computer software update. I should be ok now.
