Multiple electrical issues first gen 2001 Toyota tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Orange devil, Oct 26, 2019.
  1. Oct 26, 2019 at 4:16 PM
    Orange devil
    Orange devil [OP] New Member
    First post here ..new to the furum...I'm the original owner of my 2001 tundra sr5...shes been sitting awhile .. issues im having are .. no instrument panel gauges not working but it does light up..no AC or heat working or the radio.. also the windows will not roll up or down.and no turn signals.. check all fuses seem good to go .
  2. Oct 26, 2019 at 8:56 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    A little more information would be helpful to help you. Does the engine start and run? Did you replace the battery or charge it and verify it's still good? Did you check for chewed wires from rodents?
    MS22 likes this.
  3. Oct 26, 2019 at 9:17 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    check the mail fuels in engine bay??
  4. Oct 27, 2019 at 6:26 PM
    Orange devil
    Yes starts and runs .also charging the battery and replaced the alternator today
  5. Oct 27, 2019 at 6:48 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    I would check all wiring, if truck's been sitting for a while maybe rodents got in
    speedtre, MS22 and Orange devil[OP] like this.
  6. Oct 27, 2019 at 7:15 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Have you checked fuses?
  7. Oct 27, 2019 at 7:20 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Why did you change the alternator??
    cammiller and Aerindel like this.
  8. Oct 27, 2019 at 7:32 PM
    Orange devil
    All all fuse check good.in the engine Bay and inside the cab . after putting a new alternator in and charging up the battery..the battery is dropping while it's running .. Engine running strong .
  9. Oct 27, 2019 at 7:33 PM
    Orange devil
    I did ..now I want to test my stock one to rule out it was not the issue...also the battery I'm using is a older Red top Altima
  10. Oct 27, 2019 at 7:42 PM
    Orange devil
    The reason I changed the alternatorwas the other night when I was driving my lights went dim and I lost all power..it would start right up after a jump ...but drain the battery very fast and then die again
  11. Oct 27, 2019 at 8:47 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Those red tops are sometimes problematic.
    Sounds like you have a grounding issue. Remove and clean all grounds you can find.
  12. Oct 27, 2019 at 9:30 PM
    Orange devil
    Most definitely.. also might help if I tell you a few months back the battery had shifted in the engine compartment and the ground cable broke on the fender going to the battery and when that happen the wire on the firewall going to the block burned up. I did replace it .. but it wasn't the same gauge wiring but does not look like it has hurt it since then. Could that cause and issues not being the same Gage wire ?
  13. Oct 27, 2019 at 9:43 PM
    Aerindel
    Aerindel New Member
    Montana
    I suspect more than one ground burned up. I would check the grounds in the cabin. There is one on each side under the plastic kick panel. White and black wires. Most of the dash gauges ground on the left side under the kick panel. May be a good place to start looking.
    Perhaps this will help.
  14. Oct 27, 2019 at 10:22 PM
    Orange devil
    I definitely will check the out tomorrow.
  15. Oct 28, 2019 at 4:17 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’m not an electrician, but your new(er) grounding wire you replaced should be at least the same gauge or slightly bigger than the OEM COPPER braided.
    Clean up the contact surfaces before reinstall. Electrical grease helps if you have it.
  16. Oct 28, 2019 at 4:22 AM
    Fred
    Hand Protectors
  17. Oct 28, 2019 at 4:29 AM
    Also, check for corrosion in the fuse blocks.
    Orange devil[OP] likes this.
  18. Oct 28, 2019 at 10:09 AM
    Orange devil
    I will check the one in engine Bay first
  19. Oct 28, 2019 at 1:25 PM
    SouthPaw
    2000 Limited 4x4 AC
    Not to hijack but since I bought my truck, this ground cable has been disconnected. No issues running what so ever. What is it needed for or what does it ground?
  20. Oct 28, 2019 at 2:48 PM
    Fred
    Hand Protectors
    Seems to be the ground for the battery. Double check and make sure yours is missing and if so reconnect. Transient current flow can be a silent killer of all things effecting bearings, transmission, etc.
  21. Oct 28, 2019 at 3:02 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It's not that it is necessarily needed but there are a few reasons veh, planes, etc have numerous chassis grounds. All the different gnds(5 under my 2004 engine bay) helps keep the power clean, and reduce noise. All of our computers/sensors love it as clean as possible. By allowing for multiple grounds closest to each crucial "noise maker" if you will, you're able to ensure cleaner power. AC or DC in our case, want's to take the shortest possible path thereby not having to fight for a clean gnd.
  22. Nov 2, 2019 at 8:48 PM
    Orange devil
    Ended up being the 120amp fuse All good now
    bmf4069 and MT Madman like this.
  23. Nov 3, 2019 at 5:32 AM
    Fred
    Hand Protectors
    Thanks for following up. I wonder why it blew? Maybe that battery shift situation you had?
  24. Nov 3, 2019 at 7:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Would have swore it would be the 20 AMP....just kiddin with ya :hattip:
  25. Nov 3, 2019 at 9:36 AM
    Orange devil
    That was it..when I took it out was very brittle ..also the 7.5 amp was blown ..but I fixed that one earlier..now everything is working .. alternator charging .. radio works AC works ..windows work .. instrument panel working all except the speedometer...that ended up being the vss. Also I took the time to put bigger ground wires going to the fire wall to the engine..and the one one fender to the battery... and replaced the red top battery with a stock replacement.. decide to do a little extra TLC ..new nkg iridium plugs..new denso coil. fuel filter...I think when that red top battery shifted and ripped the ground battery on the fender then made the ground going to the engine block to the firewall burn up . Because multiple fuses to go including that big 120 amp .
  26. Nov 3, 2019 at 3:09 PM
    Orange devil
    Thank you all for your help and feed back ..I appreciate it
