Idler and tensioner pulley replacement for 2012 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by Ctmangrum, Oct 27, 2019.
  1. Oct 27, 2019 at 7:25 PM
    Ctmangrum
    Ctmangrum [OP] New Member
    2012 Tundra Base Silver 2WD
    Struggling to find the right write up or vid for this repair. Thanks.
  2. Oct 27, 2019 at 7:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm sure that there's something on YouTube.
    But with that said and having done this myself, I would recommend:
    • Drain the radiator enough that you can remove the upper radiator hose because you'll need to do that in order to remove the radiator fan shroud and radiator fan to give you much more room to work. Or you can skip that and work around those components.
    • Remove the belt.
    • Remove and replace the Idler pulley
    • Remove and replace the Tensioner pulley.
    • Install a new belt while you're in there, they're inexpensive enough.
    • Replace any other components that you may have chosen to remove (fan, shroud, upper hose and coolant).
    Done
    Okay, not done. Don't forget the transmission lines that are clipped to the shroud on the passenger side. Release clip to free hoses.
