Sway Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by JL7, Oct 27, 2019.
  1. Oct 27, 2019 at 12:25 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    All,
    Thanks in advance for any information you may have to help me with making my decision. I have a two part question.
    1. Are sway bars worth the investment? If so, is one more valuable than the other or do you need both to benefit?
    2. If I buy and would like to powder coat to match truck, does anyone know the color most comparable to Magnetic Gray?
    Thanks again guys
    Prostar 190 and TundraXPLover like this.
  2. Oct 27, 2019 at 12:29 PM
    Hellwig makes a very beefy anti sway bar and it is already powder coated in grey:thumbsup:
  3. Oct 27, 2019 at 12:31 PM
    15whtrd
    15whtrd Mr. Blonde
  4. Oct 27, 2019 at 12:33 PM
    CLowery
    CLowery New Member
    Bates City, MO
    2018 Cement Tundra TRD
    None (yet)
    I love my Hellwig
    Black Wolf likes this.
  5. Oct 27, 2019 at 1:18 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Answer to OP: YES. Rear swayer is absolutely worth it.
    I can't answer your color question. I run the Mama Toyota TRD red rear sway bar and enjoy the contrast of color.
    SuperWhite20 and BravoDeltaRomeo like this.
  6. Oct 27, 2019 at 1:24 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    Thanks guys. Should I go with front too or is rear the primary differentiator?
  7. Oct 27, 2019 at 2:17 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    Thanks again for info everyone. I ordered from link provided by Roman.
  8. Oct 27, 2019 at 2:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Tundra come with a front sway bar already, so the difference will be minimal, but the back don’t have one so when you install it, you could tell the difference.
    15whtrd and JL7[OP] like this.
  9. Oct 27, 2019 at 3:43 PM
    RRTEX1
    RRTEX1 New Member
    2016 CrewMax 1794
    Curious difference from the Hellwig vs TRD Pro rear? Hellwig looks to be more expensive
  10. Oct 27, 2019 at 3:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I replaced the front OEM sway bar with the Mama Toyota TRD (red in color) solid steel sway bar. I makes a marketable difference. Though I would say it might not be for everyone in that it tightens up the front end that much. For clarity know that I did the front sway bar swap 6 months and 12,000 miles after I added the rear TRD sway bar.
  11. Oct 27, 2019 at 3:49 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s just a TRD sway bar, not Pro. The pro doesn’t come with a rear sway. The Hellwig is either a thicker wall or diameter, even possibly solid. Most likely even more noticeable. I installed one on my Ram year’s ago, it’s a quality product.
    JL7[OP] likes this.
  12. Oct 27, 2019 at 3:53 PM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    I just posted a thread about the TRD rear. It's amazing! Love it. Just installed yesterday.
    SuperWhite20 and Warbirds like this.
  13. Oct 27, 2019 at 4:04 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    Good deal! Any tips and pearls or is it a pretty straight forward install?
  14. Oct 27, 2019 at 4:18 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    So are you saying you notice the front more then the rear??
    which one you notice more..
  15. Oct 27, 2019 at 4:24 PM
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Just read the instructions, and take your time, shouldn't take you more than an hour. I finessed my brake lines ever so slightly because I didn't like how close they were to rubbing the u bolts. Easy install.
    JL7[QUOTED][OP] and 15whtrd like this.
  16. Oct 27, 2019 at 4:26 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Put the sway bar end link first, then hook the sway bar to the end links, after that jack the sway bar up and install the u bolt, bushing and brackets.
  17. Oct 27, 2019 at 5:03 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    About one new thread per week on the “sway bar”...yes, they are very helpful...very much so provided you tow or want better handling on pavement...for the guys who want suspension travel as they drag this 6000+lb pig over off road obstacles, then you don’t want it.
    I have TRD on front and rear.
    Search is your friend.
  18. Oct 27, 2019 at 5:09 PM
    I think they are a great addition. I really like my Hellwig and it's already grey like @Black Wolf said.IMG_20190630_114135.jpg
  19. Oct 27, 2019 at 5:19 PM
    Magnetic15
    Eric
    Damn, now I'm gonna order the hellwig links so I can play with the pre-load. Looks goood
  20. Oct 27, 2019 at 5:19 PM
    :hattip:
  21. Oct 27, 2019 at 5:51 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    Irritated?
    Jaypown likes this.
  22. Oct 27, 2019 at 5:55 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    I put the red rear bar on first and discovered while it corrected handling issues it was not matched to the front(stock). So I put the red (TRD) one on the front and all was well.
  23. Oct 27, 2019 at 6:13 PM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    Easy install. Watched a few vids on YouTube. Just remember to use the white grease on the inside of the black rubber bushings. I forgot.
    JL7[QUOTED][OP] likes this.
  24. Oct 27, 2019 at 6:18 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    My 2017 SR5 did not have sway bars and the body roll was worse than my old 1970 Cadillac I had years ago.
    My new 2019 TRD Sport has the front and rear TRD bars and the difference is quite noticeable. The handling is so much tighter and firmer. I think it's worth having them.
    TundraXPLover and TILLY like this.
  25. Oct 27, 2019 at 6:21 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    ALL Tundra trucks leave the factory with a sway bar on the front.
    TundraXPLover likes this.
  26. Oct 28, 2019 at 4:21 AM
    Crunch527
    Iowa
    Not in the least...sharing that there are many recent discussions to help you out...
  27. Oct 28, 2019 at 4:38 PM
    JL7
    JL7 [OP] New Member
    18 Limited
    10-4. New at this and trying to get info in a timely manner specific to my situation without running in circles. Appreciate all the help I’ve received. Thanks
  28. Oct 28, 2019 at 5:40 PM
    Crunch527
    Iowa
    No worries...I was grunting out quickly...all good
  29. Oct 28, 2019 at 7:37 PM
    Here you go.....
  30. Oct 29, 2019 at 3:24 AM
    JL7
    JL7 [OP] New Member
    18 Limited
    You the man! Thank you
