Leveling Kit Disaster
Discussion in 'Suspension' started by ekko77, Oct 26, 2019.
  1. Oct 26, 2019 at 4:41 PM
    ekko77
    ekko77 [OP] New Member
    Erik
    2019 CrewMax LMTD
    Leveling Kit
    Leveling Kit installed in front only and Dash is a mess with warnings!!! Going tonad a 2 inch block to rear Monday wondering if this will help or should I just put everything back to stock? Any advice and help is greatly appreciated.
  2. Oct 26, 2019 at 4:44 PM
    Blueknights75
    Ron
    Clayton, NC
    Probably just need to re calibrate the TSS camera and sensor. Toyota dealership or Safelite Auto Glass can perform this calibration.
    Kerch71 and Pinay like this.
  3. Oct 26, 2019 at 4:47 PM
    Get it lifted to factory sensing
    Pinay likes this.
  4. Oct 26, 2019 at 4:48 PM
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
    Curious what kit you went with to level the front?
  5. Oct 26, 2019 at 4:57 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    There are some electrical connections at the front end, its an abs or speed sensor, something like that. Its connected right by the CV boot. Have a look and be sure it wasn't snagged during the install. Plenty of people level the front only with zero issues, including myself.
  6. Oct 26, 2019 at 5:07 PM
    ekko77
    Erik
    2019 CrewMax LMTD
    Leveling Kit
    ABS is not a issue and I know where the sensors are. It’s Pre collision, BSM and a few others. It was a Rough Country level kit.
  7. Oct 26, 2019 at 5:31 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s not a leveling kit if the truck isn’t level when you’re done LOL Our trucks have about a 2 inch rake, so if the truck is going to sit level the front can be lifted no more than 2 inches before you have to address the back to keep it level. So I’m going to assume the kit you bought is a 4/2 lift. I think I’ll get that block put in before I messed with any sensors. If the light doesn’t go out, then go and get it recalibrated or possibly have the sensors adjusted?
    Pinay likes this.
  8. Oct 26, 2019 at 5:38 PM
    ekko77
    Erik
    2019 CrewMax LMTD
    Leveling Kit
    it sits level now, hence the level kit.lol This isn’t my first time doing this. Had the same truck but a 16 , Obviously it didn’t have pre collision and some of the other sensors so there wasn’t an issue. I was thinking if I raked it like stock again it would fix itself but still sit higher in the end.
    15whtrd likes this.
  9. Oct 26, 2019 at 5:40 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m pretty sure you can get it recalibrated if you wanted to keep it level and not mess with the back. Lots of guys around here I’ve gotten away with it no problem. I guess it’s luck of the draw LOL.
    ekko77[QUOTED][OP] likes this.
  10. Oct 26, 2019 at 5:54 PM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
    Your issue is that you leveled your truck so the TSS is thrown off and you probably can no longer use your adaptive cruise control. 2019s must have a minimum of a 1 inch of rake. Which means the rear is higher by an inch. We lift these all day long at Toyteclifts and as long as we keep a little rake, zero issues but we never level them for this reason.
  11. Oct 27, 2019 at 9:03 AM
    :spy:
  12. Oct 27, 2019 at 9:15 AM
    ekko77
    Erik
    2019 CrewMax LMTD
    Leveling Kit
    Not really worried about losing the adaptive cruise control. Just can’t imagine doing this and having all these dash lights on for the time that I have this truck.
