Had a trailer tongue gouge the tailgate.
Discussion in '2nd Gen Tundras (2007-2013)' started by DocClaw, Oct 25, 2019.
  1. Oct 25, 2019 at 4:09 PM
    DocClaw
    DocClaw [OP] New Member
    2007 Tundra
    It's a straight cut in the tailgate body. Any ideas how much this is going to cost to fix?
    I don't have a picture right now but I'll post later.
    Images below...
  2. Oct 25, 2019 at 4:13 PM
    timsp8
    NY
    15whtrd likes this.
  3. Oct 25, 2019 at 4:22 PM
    DocClaw
    2007 Tundra
    Here are the images.
    @Timesp8 how much did it cost to get painted also is it very hard to remove the old shell and put the new one on?
    This isn't my truck and I want to fix it since it was my stupidity that made this happen.
  4. Oct 25, 2019 at 4:26 PM
    timsp8
    NY
    It wasn’t hard to swap everything. Don’t remember how much to paint but seems like a couple hundred maybe. Sorry, it was years ago.
  5. Oct 25, 2019 at 4:36 PM
    DocClaw
    2007 Tundra
    No problem thanks for the info I'll look into that. I'm so pissed at myself right now.
  6. Oct 25, 2019 at 4:45 PM
    15whtrd
    15whtrd Mr. Blonde
    What he showed you is just a complete tailgate minus all the moving parts. So you would get that shell and have it painted. Then switch over the handle, latches and anything else to the new one.
    timsp8 likes this.
  7. Oct 25, 2019 at 4:51 PM
    DocClaw
    2007 Tundra
    Ok is it pretty straightforward moving all the parts over? Or do I need any specific tools or anything?
  8. Oct 25, 2019 at 4:54 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Personally, I would check local junkyards. You would be surprised at what you find. Might even get lucky and match the color too. Just an idea. Good luck.
    GODZILLA and 15whtrd like this.
  9. Oct 25, 2019 at 4:55 PM
    DocClaw
    2007 Tundra
    Thanks I really appreciate the idea I'll do that for sure.
    15whtrd and Clemshady[QUOTED] like this.
  10. Oct 25, 2019 at 4:55 PM
    15whtrd
    15whtrd Mr. Blonde
    I haven’t done it myself but I’m pretty sure you’ll just need some torx bits and standard handtools. Probably I need to be careful removing tailgate cap. I have a different model than you but my bed rail caps had to be removed from underneath. That way you don’t snap the tabs off. I think you need to pinch them together to get it off. Also maybe some 3M tape to reinstall the emblems if he wants them. The body shop might even do it for you if they’re cool.
  11. Oct 25, 2019 at 4:59 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Ouch! I see this all over clist..
  12. Oct 25, 2019 at 5:02 PM
    DocClaw
    2007 Tundra
    I'll keep looking on there couldn't find one in my area just now but I'll keep looking. Thanks for this.
  13. Oct 25, 2019 at 5:02 PM
    MBI Auto on Amazon. Pre-painted shells for 3-565.00.
  14. Oct 25, 2019 at 5:09 PM
    DocClaw
    2007 Tundra
    Thanks I'll check that out. I could only see the steel color ones not how to get it pre painted the correct color. Am I missing something?
  15. Oct 25, 2019 at 6:23 PM
    You have to search around or call them direct.
    ‭(616) 209-4778‬
    Hope this helps.
    saybng likes this.
  16. Oct 25, 2019 at 6:26 PM
    Another option is to just buy the shell and have a body shop paint and blend it for you since the truck is older.
  17. Oct 26, 2019 at 6:59 AM
    DocClaw
    2007 Tundra
    Ah that is a good point. After talking to the neighbor they were thinking about getting the whole truck painted so I told them I could buy the Shell and then they could have the money towards painting it.
    They may do that. They had the hood and roof paint peeling.
    saybng and ColoradoTJ[QUOTED] like this.
