Fuel wheel help
Discussion in 'Wheels & Tires' started by Invertedflight, Oct 25, 2019.
  1. Oct 25, 2019 at 5:20 PM
    Invertedflight
    Invertedflight [OP] New Member
    Joe
    2019 Platinum
    Just starting
    I’m mounting my Fuel Maverick 20’s tomorrow on my 19 CM.
    Do I need to use the hub rings that came with the wheels or am I good without because it’s hub centric?
    thanks for the help. This forum is the s**t for modding.
  2. Oct 25, 2019 at 6:02 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    More than likely that wheel will be dual drilled 150x139.7 with the hub bore big enough for the tundra and a hub ring for a dodge.
    Just tell the shop to use them if they’ll fit or throw them away if they won’t.
  3. Oct 25, 2019 at 6:04 PM
    I don't run the ring on mine.
  4. Oct 25, 2019 at 7:15 PM
    Invertedflight
    Joe
    2019 Platinum
    Just starting
    They are duel drilled.
    I’m mounting them myself so thanks for the info.
  5. Oct 26, 2019 at 6:02 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    Mine are tight without the ring.
