What’s the best chip or programmer for my 2019 5.7 tundra?
Discussion in 'Performance and Tuning' started by hunterpedrick6, May 20, 2019.
  1. May 20, 2019 at 5:02 PM
    hunterpedrick6
    hunterpedrick6 [OP] Hunter Pedrick from Quitman ga
    Hunter
    Quitman,ga
    2019 Toyota Tundra trd off-road sport white
    Suggestions on what tuner or programmer or Chip to use on my 2019 Toyota tundra 5.7
  2. May 20, 2019 at 5:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’m very happy with my bullydog. Massive improvement
  3. May 20, 2019 at 6:21 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Stock. And it’s free.
  4. May 20, 2019 at 6:24 PM
    hunterpedrick6
    Hunter
    Quitman,ga
    Lol naw Tundra needs to get better than 19.3 mpg.
  5. May 20, 2019 at 6:37 PM
    Stig
    Stig New Member
    Since you're not looking for performance but just better mpg, you'd be a good candidate for a custom tune.
    Someone could probably write you one that only allows the throttle to open 25% and a speed governor set to 55.
    Besides that, all you can really do is pump your tires up and mimic the driving style of those Prius's that are often drafting behind semis.
  6. Jun 6, 2019 at 3:08 AM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Lmao, omg man...wew look you just should not buy a tundra and expect to get "good gas mileage " cruise at 70 and 18 mpg is what I get and that's just amazing. Better then 19.3???? Just sell it
    Corndog123 and GODZILLA like this.
  7. Jun 6, 2019 at 4:30 AM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    I thought a lot about a programmer, and had one for my previous F150. Then I heard about beast mode. Decided 55-65 was best way to get better mileage and use beast mode for performance.
    GODZILLA likes this.
  8. Jun 6, 2019 at 5:20 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Bump It up some and find the sweet spot for your truck. My 13 TSS was way above 70. Our/my new truck gets horrible gas mileage but with the additions in town I already notice a difference so curious to see what it does on the HWY. hoping to get better than 16 but I doubt it???:) be happy with the 19, that is pretty good.
  9. Jun 6, 2019 at 9:05 AM
    Tigwelder
    Tigwelder New Member
    I was happy when I hit 6k miles my truck went from 13.7 mpg to 14.5
    I mean like crazy happy with it.
    I wouldn't know what to do if it got 17-18 mpg
    If a program would do it . I'd buy one
    BlueDream likes this.
  10. Jun 10, 2019 at 10:22 AM
    tundraal
    tundraal New Member
    If you are getting 19.3 MPG, then you already are getting good gas mileage!
    15-17 is the norm.
    Limited Tundra 18 and GODZILLA like this.
  11. Oct 24, 2019 at 11:47 AM
    Rizuri Motorsport
    Rizuri Motorsport New Member
    Dante
    2014 Tundra; Django's Chariolt
    20' Method Con 6 Wheels 35" Atturo Trail Blade XT 4" Fabtec Coilover lift/ Uniballs 20% carbon windshield & window film Borla cat-back exhaust S&B cold air intake Kicker C2 6x9s & 6.5s
    lol... 9.9 mpg
  12. Oct 24, 2019 at 2:47 PM
    BMalpass
    BMalpass New Member
    Are you really asking for better than 19.3mpg on a Tundra?
    You bought the wrong truck... also... how do you get 19.3? Asking for almost EVERY other member here.
  13. Oct 24, 2019 at 2:50 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Seems like my truck likes to average in the 15-16 mixed now.
  14. Oct 24, 2019 at 3:18 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I’m lucky if I get 15mpg
    Nighthawk likes this.
  15. Oct 24, 2019 at 7:03 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Heres how you achieve 20mpg:
    - Stock tires @ 50 PSI
    - drive at Sea Level
    - drive 55mph on interstate
    - cruise control
    - washed/waxed truck
    - 2wd truck
    :p
  16. Nov 3, 2019 at 3:48 PM
    Devildog183
    Devildog183 New Member
    Roger
    Kansas
    2019 Limited CM 4x4 2007 SR5 DC 4x4
    Crap my new 2019 get 12-13 how the hell does anyone get 19? Always coasting down hill to work both ways lol
  17. Nov 3, 2019 at 3:58 PM
    Vancepp
    Vancepp New Member
    2017 TRD Off Road
    Toytec Boss Kit, Method Grids, 305/70-18 STT Pros
    Squeezing a solid 11 mpg out of mine. I would love to see 19. Just not going to happen.
  18. Dec 11, 2019 at 10:55 AM
    muledawg
    muledawg New Member
    Indianapolis,IN
    2019 Silver Sky Metallic TRD CM
    I was just hoping to get 15 out of my 2019 crewmax and I do. (10-11 Towing) Going into this purchase knowing this rig had a 4.30 ratio running gear, 5.7L, I knew I was gonna sacrifice fuel mileage. Most people don’t look at this aspect in buying a truck. I didn’t want a 3/4 ton truck in which most have a 3.73 or 4.10 gear ratio. It is a half ton truck built for towing which I wanted. It’s a beast
    Rebel Tundra Man likes this.
  19. Dec 11, 2019 at 11:40 AM
    Black@Blue19
    Ken
    SE Texas
  20. Dec 11, 2019 at 7:24 PM
    Tundra_power
    Tundra_power New Member
    Its not all about rear end gear. Its about the total package that impacts acceleration and mpg. Ford, dodge and chevy all used gearing around 3.73 or below that because the transmission gearing is more steeper "higher numerical number" than our tundras. If you calculated ford transmission gear plus rear end gear it has more acceleration in 1 or 2nd gear but in 3 and 4 we have more torque multiply just for towing. Around 3000 rpms is the sweet spot. No matter what trucks will all get bad gas mileage theirs no way around it only turbos and electric will get you good mpg. Yes people say f150 5.0 gets great mpg and its a v8. Well f150 is about 800 pounds lighter and with 0.7L smaller engine and 10 speed automatic i would hope you get better mpg. But with 10x less the reliability of a tundra. When the new tundra is coming out its going to be like in 2007, best truck of the year guarantee. If Toyota can pull off a v8 with really good power numbers and 20ish mpg average and v6 turbo/hybrid with 30mpg is insane too. But for me i will always choose v8.
    Atlas415 and muledawg[QUOTED] like this.
  21. Dec 20, 2019 at 1:49 PM
    Michaelb1100
    Michaelb1100 New Member
    2018 SR5 TSS 4x4 CrewMax
    MACH Force-Xp 2-1/2" to 3" 409 Stainless Steel Cat-Back Exhaust System, AFE Magnum FORCE Stage-2 Si Cold Air Intake System w/Pro 5R Filter Media
    Bigboitundra likes this.
  22. Dec 30, 2019 at 6:52 AM
    Aaron713
    Aaron713 New Member
    This thread is completely useless as named. OP, please change to "Mileage debate and no conversation about programmers"
    Corndog123, CT1990, Wildtrout and 4 others like this.
  23. Jan 8, 2020 at 9:03 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My 2020 sees 19mpg on the highway running 65mph. I will drop to 18 running 70-75mph. The best I've seen was 21mpg running at sea level (Florida), no head wind and 55mph on a dead flat road.
  24. Jan 9, 2020 at 3:25 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I checked the bully dog website and they don’t show a tuner for 2018 and up Tundras
  25. Jan 9, 2020 at 3:52 AM
    Atlas415
    Atlas415 New Member
    Well said, and great looking truck you got there in your sig. block
  26. Jan 9, 2020 at 4:04 AM
    timsp8
    NY
    Pretty sure it’s cause of the safety stuff Toyota added in 2018. They don’t want you to mess with anything that would make them responsible.
    Doxiedad[QUOTED] likes this.
  27. Jan 9, 2020 at 4:27 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    do it.... it is so worth it :)
