Block Heater
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Oct 23, 2019.
  1. Oct 23, 2019 at 1:26 AM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I installed a block heater in my last truck(2010F150) and am looking to do the same with my Tundra.
    Who out there has installed one and what type was it( cartridge, threaded, freeze plug)?
    I have found what I think is one for my truck according to Phillips & Temro's website (zerostat 3100129), but it says its a "cartridge type". From what I have read, it means that it sits in an empty hole in the block casting with no contact with engine coolant. Does this work well? I would think that heating up the coolant would be more efficient, but if this works im willing to give it a try.
  2. Oct 23, 2019 at 1:29 AM
    awq735
    Anthony
    Ohio
    I guess I should mention that my previous truck had a freeze plug type heater that did come into contact with engine coolant. That is why I am sceptacle about the cartridge type heater.
  3. Oct 23, 2019 at 3:14 AM
    timsp8
    NY
    Toyota has a stock one that goes in a hole on the lower drivers side. I’ll look for the part #. Its pretty easy to install, takes about 5 min. It heats the block directly, not the coolant.
    Edit: PU140-00913-2
  4. Oct 23, 2019 at 4:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have one like this. It has a heat conductive slop that you also put in the hole to transfer heat. It works well and there's no chance of a coolant leak. :p It takes longer to run the power cord than to install the element itself. I haven't really looked, are there even frost plugs on these engines? o_O
  5. Oct 23, 2019 at 2:11 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    When searching this part number, the only result I could find is in eBay. In the description it says that it's a "Toyota of Canada block heater". This should still work, right? It also says it doesn't come with instructions. Do you have a pic of where this plugs into or any other info? Thanks
    https://www.ebay.com/ulk/itm/272939892532
  6. Oct 23, 2019 at 2:15 PM
    timsp8
    NY
    Once you see the hole you can’t unsee it.
    I’ll take a pic next time I can get under my truck. I think Toyota USA stopped selling them. They aren’t even an option. I bought one in 2010 locally. Had to order a Canadian one off eBay for my 2018. It’s the same thing. I believe it’s also still an option in Canada, like remote start and dash cam that we don’t get.
    Tumungaloo and WFD473 like this.
  7. Oct 23, 2019 at 3:31 PM
    Mark843
    Mark843 New Member
    Mark
    WNY
    2018 Barcelona Red Tundra SR5 with TRD offroad package
    @Roman Is this a part you sell?
  8. Oct 23, 2019 at 3:37 PM
    awq735
    Anthony
    Ohio
    At $75 off eBay I may just get the Zerostart heater off Amazon. Thanks to all of the helpful information and if I can convince the CFO of the house that its a necessity I will update with pics!
    Zerostart 3100129 Engine Block Cartridge Style Heater for Chevrolet, Lexus, Pontiac, Scion, Toyota | CSA Approved | 120 Volts | 400 Watts https://www.amazon.com/dp/B006ENE7A6/ref=cm_sw_r_cp_apa_i_XwnSDbC9EW502
    Super Lube 98003 Silicone Heat Sink, 3 oz Tube, White https://www.amazon.com/dp/B0044NI2M2/ref=cm_sw_r_cp_apa_i_pxnSDb8862M44
    WFD473 and TRD-tv like this.
  9. Oct 23, 2019 at 4:39 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    In 2018 I bought my 2015 SR5 here in Michigan although it came out of Quebec. Has a Toyota block heater already installed.
    At what temps do those of you with these plug them in to heat your block?
    Please respond in Fahrenheit... don't make me do any math.....thanks...
  10. Oct 23, 2019 at 5:06 PM
    awq735
    Anthony
    Ohio
    On my ford I would plug it in when the overnight temps dropped below 40 degrees F. I had the heater plugged into a timer that would let the heater run for 4 hours prior to me leaving for work.
    I'm sure some plug them in only when it drops below 32 degrees F but it sure is nice to get in the truck and have heat instantly when the engine is started, even on above freezing temp days.
    Shadowfax1 likes this.
  11. Oct 23, 2019 at 5:31 PM
    Haggis777
    SW Michigan
    Cool! Thanks for the quick response!
  12. Oct 23, 2019 at 5:38 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    is it worth getting one of these for a gasser? i live in ohio and we see pretty brutal winters but i was always told u dont need em in gas engines
  13. Oct 23, 2019 at 5:55 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Honestly, here when your going to get into single digits and below zero, then plug it in. Other than that I feel it's just a waste of electricity.
    MJoeP and Cpl_Punishment like this.
  14. Oct 23, 2019 at 7:45 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm more in line with this, unless the truck is parked at work and they're paying for the juice. 20°F is when I begin to think about it.
    Dr Doobie likes this.
  15. Oct 23, 2019 at 8:03 PM
    jstchilln
    jstchilln New Member
    Larry
    Eastern Kansas
    2017 Tundra 4X4 SR5 Double Cab / TRD Off road Package
    TRD Pro Grille
    I had one of the old type that went into the freeze plug when I had my good old SR5 T-100. We only had a 1 car garage and I had to park the truck outside at home and the fire station and I liked the idea of a block heater. The truck only took a few miles to blow warm air even on zero degree nights.Also, the heat from the coolant would go through the defroster and partially defrost the windshield. After 15 years I bought a Tacoma and used the cartridge type of block heater when I was at work since we had moved into a house with a two car garage. The cartridge was very easy to install and I believe I had to order it from Canada.
    Here are a couple of pictures I took through our Thermal imaging camera at work after a cold night and the block was at 42 degrees which isnt all that bad.
    WFD473 likes this.
  16. Oct 24, 2019 at 6:52 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    No sir, we do not sell block heaters. Being in the south, we don't really need them. :D
    I'm pretty sure most northern dealers would either be able to get them or can acquire them.
    NewImprovedRon likes this.
  17. Oct 28, 2019 at 1:24 AM
    awq735
    Anthony
    Ohio
    I got the heat conductive goop in the mail on Saturday and the heater should be here Wednesday. I'll post pics when I get it!
    Magnetic15 and Wynnded like this.
  18. Oct 28, 2019 at 6:26 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I normally plug in around -4F (-20C). I've gone beyond that without too much trouble but the car can also struggle to start at temperatures above that and you know you're being hard on the battery, starter, etc. If I were you, I would consider just plugging in any time it gets below 0F for simplicity.
    Edit: looking at the responses above, I tend to laugh at the folks I see who plug in at 30F unless they have really old cars with weak batteries.
    snivilous and BravoDeltaRomeo like this.
  19. Oct 30, 2019 at 10:25 AM
    awq735
    Anthony
    Ohio
    Is this the hole that you cant unsee?
    I just put my truck up on ramps in anticipation of the part being delivered soon!
  20. Oct 30, 2019 at 10:38 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    They're mandatory in Canada vehicles from what I know
    We try to plug in when it hits about -15c or 5f or so, if I remember. Regardless, I let the vehicle warm up 5min or so when it's winter as wind chill usually makes it feel much colder.
    My rule of thumb is....if it's outdoor hockey weather, the vehicle doesn't need to be plugged in. That's usually -20c or -4c
    Cpl_Punishment and HulkSmurf14 like this.
  21. Oct 30, 2019 at 12:19 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I had my dealer install mine last year. Works great. Since I live in SE pa, Toyota didnt list it as a part available for the dealer in my area. So the tech was smart and ordered the block heater threw a dealer in Canada and had it shipped to pa. The tech said Toyota is funny with what parts are available for different regions.
  22. Oct 30, 2019 at 12:40 PM
    timsp8
    NY
    It looks like it. I forgot all about taking a pic. I’ll try to get one this week.
  23. Oct 30, 2019 at 1:34 PM
    awq735
    Anthony
    Ohio
    No worries.... That was the place. As it turns out, you can put too much of the heat conductive grease in the hole. I had to scrape most of it back out for the heater to fit in. You were right, it took longer to route the cord than it did to install the heater. heres to warm mornings in the near future!
  24. Oct 30, 2019 at 1:52 PM
    TemujinNomad
    TemujinNomad New Member
    Hit 10c last night. Truck wouldn’t start with key but cranked just fine with remote start. Any thoughts? Thanks
  25. Oct 30, 2019 at 2:15 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Do you remember how much the part was through the dealer?
  26. Oct 30, 2019 at 2:31 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    10c? That's not cold at all.
  27. Oct 30, 2019 at 2:45 PM
    TemujinNomad
    Sorry 10f
  28. Oct 30, 2019 at 5:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ford/Chevy/Other? ;)
    BravoDeltaRomeo likes this.
  29. Oct 30, 2019 at 9:17 PM
    TemujinNomad
    Tundra. Odyssey agm
  30. Oct 30, 2019 at 9:23 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    I only run a block heater on diesels, and only when it drops to negative numbers. New injection engines don't need them until you start getting into the negative double digits. And even then, a battery blanket adds more value. Just my 2 cents. Btw, this morning it was -3, started right up.
