Bilstein
Discussion in 'Suspension' started by Basskrazee, Dec 13, 2016.
  1. Dec 13, 2016 at 3:24 AM
    Basskrazee
    Basskrazee [OP] Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    I'm going to install the Bilstein 6112 coilovers. Should I use 1 shim on the drivers side and nothing on the passenger side? Or install 2 on the passenger side and 1 on the drivers side? I would like to get a 3" lift in the front. Will new UCAs be needed? If yes what brand world work best. Thanks for the help.
  2. Dec 13, 2016 at 3:31 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Is your truck leaning left to right? Mine did not. It was even before and after the lift.
    If your truck is leaning and the driver side is lower by 1/2 inch, then you will need a shim on the left side. If you want 3 inches, you will have to use 2 on the driver's side and 1 on the passenger side. Bilstein struts don't give you 3 inches even at the highest setting. At 3 inches, you probably won't need a set of new UCAs.
    MotoTundra likes this.
  3. Dec 15, 2016 at 2:31 AM
    UsmcPro86
    UsmcPro86 New Member
    Basskrazee i have brand new TRD PRO biltein shocks for sale if ur looking for some
  4. Dec 15, 2016 at 8:51 AM
    Basskrazee
    Basskrazee [OP] Pop
    Joe
    Indianapolis, IN.
    Thanks USMC Pro86, but I purchased Bilstein.
  5. Dec 15, 2016 at 10:12 AM
    Carlos@Camburg
    Carlos@Camburg Carlos @ Camburg Vendor
    Carlos
    Huntington Beach
    2015 Tundra DC
    Camburg UCA Bilstein 6112 KMC Wheels General Tires Rigid Lights
    You wont need to shim either side. At least i didn't and Ive never done it on any of the trucks weve installed the 6112s on (weve done a few).
    If you're going to set it up at 3" you deff want to run an upper control arm. You're going to get the best ride results with something that corrects your geometry and allows you to get it aligned properly.
    If you plan on doing mostly street driving, id consider doing something like our ball joint upper arms. Nice & quite with low maintenance..
  6. Dec 15, 2016 at 10:17 AM
    UsmcPro86
    No problem let me know if you know anyone
