18x9 +25 Method NV on 295/70/18
Discussion in 'Wheels & Tires' started by TwistedTad, Apr 24, 2019.
  1. Apr 24, 2019 at 5:56 PM
    TwistedTad
    TwistedTad [OP] TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Would this be a good setup on a Toytec 3/1.5? No finder flares. Hopefully no BMC and minimal liner trimming!!!
  2. Apr 25, 2019 at 1:55 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    If you had closer to stock offset I'd say you're good, but i think you're going to have to trim a lil bit. try searching on here a little bit in wheel and tire section. there's alot of them posted that should be able to shed some light on it for you.
  3. Apr 25, 2019 at 2:14 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Should be ok. +18-+25 offset should get you away from control arms. May have to heat and move liner a little bit.
    A 285/75 tire should fit with 3 inches lift in the front. 295/70 is just slightly shorter and slightly fatter.
  4. Apr 25, 2019 at 2:21 PM
    dawgfan706
    dawgfan706 New Member
    I have the Method NV on 295/70/18 Nitto Ridge grapplers. Lift installed is the toytec eibach kit with shackles set on 1.5. I did have to push the front liner in on both sides.
    jewsNbrews likes this.
  5. Apr 25, 2019 at 2:29 PM
    TheBeast
    TheBeast The Beach
    some pushing/trimming but no BMC. I did the BMC however for peace of mind. running Method +18 and 295/70/18
  6. Apr 25, 2019 at 2:31 PM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    Shouldn’t have any problem except for pushing your inner liner forward. I’m running 315/70r17 tires with a +25 offset wheel, and only had to remove the little front mud flaps and pushed the inner liner forward.
  7. Apr 25, 2019 at 2:57 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks guys!!! Im going to start a build thread and hopefully all goes well with this 3/1.5 with the 295’s. Probably going to start in the next couple of weeks. Waiting on the 1/4 shim for the drivers side.
  8. Apr 25, 2019 at 3:20 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    I think my method NV 18x9 have the +25 offset, and I had to use a 1 1/4 spacer up front, or the wheels hit the control arm, not the tire.
  9. Apr 25, 2019 at 3:48 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I have 295/70/18's on Vision +25s and only need a TINY bit of fender mods. So little that I've never even gotten around to doing it.
    Probably about 2.5/1in lift
  10. Apr 25, 2019 at 4:31 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks again guys!!! All the input is very helpful!!! There is enough great information on this forum to make your head spin and your bank account go down!!!
  11. Apr 25, 2019 at 4:33 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    It will work perfect get em I have 0 offset methods and it took no more trimming then what +18 did which was the offset I have first. Just removed your mud flap and either cut out or heat the inner liner and push it in.
  12. Apr 26, 2019 at 6:12 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    Thanks @xtyfighterx . I saw your build page. Wow!!! I see you have done a couple of things to your Tundra. Nice truck!!!
    xtyfighterx likes this.
  13. Apr 26, 2019 at 10:53 AM
    TwistedTad
    Tad
    Canyon Lake, CA
  14. Apr 26, 2019 at 2:15 PM
    xtyfighterx
    Ty
    North Idaho
    Thanks! +18 were fine I just didn’t like my wheels I had I only got them cUz they were on clearance at the time.....I think 0 offset is my ideal stance. But any methods on our trucks loOk great you can’t go wrong
  15. Apr 26, 2019 at 4:53 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    More presents today!!!!
    pschiller86 and jewsNbrews like this.
  16. Apr 26, 2019 at 6:09 PM
    xtyfighterx
    Ty
    North Idaho
    My next tire! Great choice
  17. Apr 26, 2019 at 6:10 PM
    xtyfighterx
    Ty
    North Idaho
    What did they run you? I have to buy this summer
  18. Apr 26, 2019 at 7:31 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    @xtyfighterx I got the from tires direct. They had a special last week. Buy 3 get 1 free on all Toyos plus free shipping. Tires were $1029 shipped to my front door. 55k mile tread life!!!! . I won’t need new tire for awhile. Also I love the stance of your truck but just want the tires tucked in a little more so I think +18 is the way I will go. I have a friend who works at Method and can get me rims at a great price. Thanks again for all your input.
  19. May 4, 2019 at 5:25 PM
    dawgfan706
    I have the +25 on 295/70/18
    81A03013-6463-4CA5-9718-2F9E4431F7A7.jpg F77E9D84-671C-4826-948D-C745FD3028AF.jpg
    Tundra17Tom and jewsNbrews like this.
  20. May 5, 2019 at 6:44 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    @dawgfan706 Nice truck!!! Did you have to do a BMC or any finder liner work? Thanks!!!
  21. May 5, 2019 at 7:18 AM
    dawgfan706
    @TwistedTad just had to remove flaps and push front liner in some.
  22. Oct 20, 2019 at 3:58 PM
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    Nice truck! Is your truck lifted or leveled? I was considering+25 offset and either 295/70/18 or 285/70/18, my truck is leveled... Any issues with rubbing fender or frame or any issue with tires hitting UCA? Thanks for information!
  23. Oct 20, 2019 at 4:01 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    +20 18x9 295/70. No bmc, only mudflap trim, front bumper spaced out 1” and also plastic trimming in front.
  24. Oct 20, 2019 at 5:38 PM
    dawgfan706
    I have the 3/1.5 eibach met from toytec installed. Had to remove front mud flap and push the front liner in some.
  25. Oct 20, 2019 at 6:18 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Looks perfect.
    MAGDADDY[QUOTED] likes this.
