Go Rhino Dominator D6 Running Boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by Highsierraguy, Sep 29, 2019.
  1. Sep 29, 2019 at 5:45 PM
    Highsierraguy
    Highsierraguy [OP] New Member
    Nor Cal
  2. Sep 29, 2019 at 5:53 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Based on the mounts I sure wouldn’t try sliding on them...
  3. Sep 29, 2019 at 5:57 PM
    Highsierraguy
    Nor Cal
    Not looking for actual sliders, which is why I was between the different blade styles.
  4. Oct 19, 2019 at 2:55 PM
    Highsierraguy
    Nor Cal
    Ended up purchasing these and happy with them after installing today. They are pretty solid with no flex when I stand on them. I added a 1 inch strip of 3M grip tape on the tube.
    IMG-20191017-182716_a0705b444d82cdc2fe9a0b923689b04cc01812e1.jpg IMG-20191017-183258_e24f786ba250cbb84377f3c6ebf41aece91d3ea0.jpg IMG-20191019-143826_7553acecf37f340b49e67288749198700894fd91.jpg IMG-20191019-143838_b52831eb8a662598d4c010c310d5edce3b0c8af4.jpg IMG-20191019-143846_3428eac1797c5d452488f2ca6b031bacdca5f309.jpg
  5. Oct 19, 2019 at 2:59 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Looks great, I’ve got the BR20 boards and like them a lot. Like the style of yours.
  6. Oct 19, 2019 at 3:25 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Huge fan of the RB20s. Look awesome.
    MAGDADDY likes this.
  7. Oct 19, 2019 at 7:27 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Those look good. Do you have a shot from the side of your truck? How’s the alignment with the cab? I have seen some go rhinos that are higher (closer to the rocker) in the front than in the back
    Tundra805 likes this.
  8. Oct 20, 2019 at 9:39 AM
    Highsierraguy
    Nor Cal
    The alignment is perfect, you can adjust the boards up or down, or shift them forward or backwards before tightening them. The brackets are on this rail system which was weird at first, but useful once you're trying to adjust them.
    IMG-20191020-083552_0d77b4a2a4182b0f9f2932198ceafaca16293f55.jpg IMG-20191020-083600_a3265cf270b9fd7aaaa8eb90b4d4605a630bbdfa.jpg
    Tundra805, cch2a and JH5370[QUOTED] like this.
  9. Oct 20, 2019 at 10:25 AM
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    You can't use the Tyger blades (if I recall) unless you have a Double Cab. You have a CM so that rules them out. RB20's it is.
  10. Oct 20, 2019 at 1:47 PM
    cch2a
    cch2a New Member
    Glad you posted these. I also have been looking at the same styles. I also don't need actual sliders but want something tucked in close to the body that my 5 year old can use to help get in the truck. I tend to not like anything hanging down. Looks good.
