05 Cam Bearing Cap help.
Discussion in '1st Gen Tundras (2000-2006)' started by TheBeeGuy, Sep 17, 2019.
  1. Sep 17, 2019 at 3:15 PM
    TheBeeGuy
    TheBeeGuy [OP] New Member
    James
    2005 Tundra
    F42F3F9D-9E4D-4C56-8083-BE0AEF475815.jpg 7BE15E8E-F965-4FF6-BF29-D66D3BF4EB41.jpg 5647B617-03FF-44C0-BA9D-3C051C726325.jpg Hello .
    Everyone new to the forum.
    Have searched high, and low for information on this, and haven’t quite found it.
    My 05 tundra started leaking oil from the cam bearing cap, was time to do a timing belt, anyways so I figured I’d reseal this, and do the valve covers/plug seals at the same time.
    However after removing the bearing cap I found the previous owner had put silicone in all the groves. From what I understand the groves don’t get RTV , and only the sides do. Wanted to see if someone with more experience can help me out. Attached are pics of the service documents, and a pic of my bearing cap.
    speedtre likes this.
  2. Sep 18, 2019 at 10:37 AM
    TheBeeGuy
    James
    2005 Tundra
    Decided to not put sealant in the groves as all the service documents, and My book say not too.
    The previous owner took it to have the timing belt done, and it seems like someone decided to try to do the cam seals, but stopped after finding out what all it takes to do the cam seals.
    There was a leak the seams to be coming from the cover. Not necessarily from the cam seal. I’ll have to recheck when I get it all back together.
  3. Sep 18, 2019 at 10:40 AM
    It could be from the VC itself. It needs a dab of rtv in the corners where it goes up for the cams.
  4. Sep 18, 2019 at 10:55 AM
    TheBeeGuy
    James
    2005 Tundra
    Anyway you could post a pic. I’ve always had Honda’s used it on the sharp corners over cams, and my 92 yota was pretty much the same.
  5. Sep 18, 2019 at 3:13 PM
  6. Sep 18, 2019 at 8:33 PM
    TheBeeGuy
    James
    2005 Tundra
    You’re awesome! I hit those spots, and redid the rear plugs . Those were the spots I figured you were talking about. Thanks for confirmation!.
    She’s back together, and runs great. Flushing my cooling system as the previous owner only used water.....
    Also going to be looking for what sounds to be an exhaust manifold leak.
    bmf4069[QUOTED] and TX-TRD1stGEN like this.
  7. Oct 18, 2019 at 2:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
  8. Oct 18, 2019 at 10:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    those grooves in the part are there to have the sealant smush into. when you apply the sealant where the FSM shows once you tighten down the part it gets into the grooves and thats what creates your seal.
