Need to install an outlet
Discussion in 'Home Improvement' started by Ps3udonymous, Oct 18, 2019.
  1. Oct 18, 2019 at 3:59 PM
    Ps3udonymous
    Ps3udonymous [OP] Who is the smart ass that changed the title?
    Got a small freezer that I want to put in the garage. However, the only space I have doesn't have an outlet. However, there are some light switches close by.
    My question is, how can I get power from the hot side of the switch to go to the outlet. It's got three wires, hot neutral and ground. Can I basically tap in to the hot wires and run them to my outlet?
  2. Oct 18, 2019 at 4:02 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Yup but turn breaker OFF after you locate the constant hot!
    :hattip:
  3. Oct 18, 2019 at 4:05 PM
    longcat
    longcat New Member
    Jon
    DFW / Texas
    2019 Cavalry Blue Tundra CrewMax
    You'll want it the switch outlet between the same studs that the switch is in between if your going for easy. You can go perpendicular across studs if you want but it's more of a pain and involves more tools.
    Here is a good how to:
    https://www.youtube.com/watch?v=_p79UHZb09Y
    One thing you'll want to do is mount that plug up a bit if it is in your garage. I actually have mine about 5 feet off the ground just in case I have a water heater catastrophe (it lives in the garage) or any other flooding issue.
    TokerJoker likes this.
  4. Oct 18, 2019 at 4:05 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Yes it can be done ez peezy! I ain't an electrician. I've done it tho, be safe, do your homework and don't burn down the house!:thumbsup:
  5. Oct 18, 2019 at 4:06 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    ^^^He knows his shit bro!^^^
    Ps3udonymous[OP] likes this.
  6. Oct 18, 2019 at 4:23 PM
    Ps3udonymous
    This was basically my plan. To install it level with the existing light switches. Thanks for the quick responses
  7. Oct 18, 2019 at 4:24 PM
    Ps3udonymous
    This is me doing my homework lol. And I definitely don't want to burn down my house
    OR18TRD likes this.
  8. Oct 18, 2019 at 4:38 PM
    PowerMan81
    PowerMan81 New Member
    Nor Cal
    2019 Tundra DC SR5 4x4
    As long as there are at least two romex’s in the box. Sometimes they run a “dead end switch leg” which won’t have a neutral in the box. If there at least two white wires spliced then You’re good to go. If the white plugs into the switch you’re outta luck. It sounds like it’s a multi gang so most likely you have regular power there so it should be fine. Also in a garage you need a GFI outlet by code.
  9. Oct 18, 2019 at 4:51 PM
    Ps3udonymous
    That's what I ended up grabbing. Why would a gfci be required in the garage?
  10. Oct 18, 2019 at 5:03 PM
    PowerMan81
    Nor Cal
    It’s because they consider an area where you could come in contact with water and have a potential shock hazard.
    OR18TRD likes this.
  11. Oct 18, 2019 at 7:11 PM
    Ps3udonymous
    Makes sense. Well thank you all for the answers. Very useful pool of knowledge
  12. Oct 18, 2019 at 7:41 PM
    buddy89
    buddy89 New Member
    SoCal/northern Az
    2015 Tundra dc sr5
    While gfci protection is required in sfd garage I do not recommend it for a fridge. Fridges tend to trip gfci’s in turn wasting everything inside if not caught in time. I’m a journeyman electrician, pm with any questions. Good luck!
    OR18TRD likes this.
  13. Oct 18, 2019 at 7:57 PM
    PowerMan81
    Nor Cal
    I’m a journeyman electrician too and I understand where you’re coming from. The chances are pretty low of someone getting shocked are pretty low, but it is still technically the code requirement especially if it’s somewhere something else could be plugged in.
