Just got a 2006 tundra sr5, will a 275/65r18 fit okay? I have the 16 inch now
Discussion in '1st Gen Tundras (2000-2006)' started by Brandonflorida, Oct 11, 2019.
  1. Oct 11, 2019 at 10:26 AM
    Brandonflorida
    Brandonflorida [OP] New Member
    Brandon
    2006 Tundra access cab SR5 with the ugly bed
    none
    With a adapter i have a killer deal on rims and new tires (200) and need to see if anyone has any idea if that size would fit on this 06 tundra sr5. Any help would be great, Thanks
    Also the Radio volume doesnt move at all. Is that a radio issue or could it be the amp?
  2. Oct 11, 2019 at 10:28 AM
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
  3. Oct 11, 2019 at 10:30 AM
    bobwalk2002
    bobwalk2002 New Member
    Bobby
    Prescott, AZ
    2010 Tundra SR5 Double Cab TRD Off Road 4x4
    None yet.
    I have a stock 2010 Tundra SR5 TRD. It came from the factory with 275/65 R18, so I don't see a problem.
    Update: I just realized your 2006 is a first Gen, so I don't know. The guide that was provided should tell you.
  4. Oct 11, 2019 at 10:31 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Why ditch 16s?
  5. Oct 11, 2019 at 10:50 AM
    Brandonflorida
    Brandon
    none
    Ok, according to the guide they will not fit. The 16's i have are steel wheels. The 18's are 200 for the tire and rim. Great deal but won't work and they are nice looking. Oh well
  6. Oct 11, 2019 at 11:15 AM
    Don't quote me, but I've heard that they dont make as many sizes as 17s or 18s.
  7. Oct 11, 2019 at 11:16 AM
    If your deck is factory try pulling on the knob and turning it. That's what I have to do.
  8. Oct 11, 2019 at 11:36 AM
    Mwray8909
    Chino Valley
    Ah. I just would prefer more rubber than rim.
  9. Oct 11, 2019 at 11:46 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    The 2006 Darrell Waltrip Edition came with 18 x 9 BBS wheels, P275/55R18 tire size.2006-toyota-tundra-crew-cab-darrell-waltrip-edition-1.jpg
  10. Oct 11, 2019 at 12:08 PM
    Brandonflorida
    Brandon
    none
    Well that gives me hope. A 275/65r18 would probably work. Its just tough because I would need to get adapters for it and cant really test fit them.
  11. Oct 11, 2019 at 12:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    We had a 2004 Highlander before We traded up to a 2017. The 2004 Highlander radio, which is similar to or same model as my 2004 Tundra and possibly same for 2006 SR5, I think ?
    All that to say, the problem We had on the 2004 was the volume would indeed not adjust but most of the time even if you veryyyy slightly rotated volume knob, it would jump from vol 10 to say 30 or vice versa. Damn thing had a mind of it's own. Found a fairly new one at our Local pick-a-part place(Raceway) and everything was then good in the world again !
  12. Oct 11, 2019 at 12:50 PM
    SoCalPaul
    Paul
    What kind of adapter?
  13. Oct 11, 2019 at 3:20 PM
    I SAID DONT QUOTE ME! :D
    BubbaW likes this.
  14. Oct 11, 2019 at 3:55 PM
    Mwray8909
    Chino Valley
    Oh my bad....
    bmf4069[QUOTED] likes this.
  15. Oct 12, 2019 at 10:34 AM
    Brandonflorida
    Brandon
    none
    6 Lug to 5 lug
  16. Oct 16, 2019 at 2:51 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Hows your decision working out Brandon?
  17. Oct 16, 2019 at 3:20 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    I would not think of reducing from 6 lug to 5 lug. Trust that the Toyota engineering designed it that way for a reason, which involves a lot of physics, mechanical parts, and equations considering horsepower, weight, braking, etc.
    I have 275/65/18's on my 2005 DC and they fit great. Just need to lift it about 2", which I did with Icon 2.5 coilovers.
