1st gen abs bleed
Discussion in '1st Gen Tundras (2000-2006)' started by PowSlayer, Oct 13, 2019.
  1. Oct 13, 2019 at 4:33 PM
    PowSlayer
    PowSlayer [OP] New Member
    2000 Tundra
    Hey guys does anyone know in what order to bleed the brakes on an abs system?
  2. Oct 13, 2019 at 4:36 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Go find a dirt road, take it up to 30mph and lock them up. Do that a couple times, go back and bleed them like normal
  3. Oct 13, 2019 at 4:48 PM
    PowSlayer
    2000 Tundra
    as in starting with RR and ending with FL?
  4. Oct 13, 2019 at 4:52 PM
    I believe it's rear passenger, rear driver, LSPV, front passenger, front driver.
    Don't forget the 3rd one, LSPV. It's in front of the spare tire.
  5. Oct 13, 2019 at 6:13 PM
    Aerindel
    Aerindel New Member
    Montana
    I have drained my system completely and bled through the normal methods without problem. There is no mention of any kind in the factory service manual of bleeding the ABS system, and from my experience, no method for doing this, or reason to do this. I always bleed normally according to the recommended order of Front driver, back passenger, Front passenger, rear driver, LSPV. Although I do not really think the order matters.
    TX-TRD1stGEN and Darkness like this.
  6. Oct 16, 2019 at 9:44 AM
    PowSlayer
    2000 Tundra
    I had problem with one line... a lot of pressure built up and the pedal stayed very stiff and the fluid was just trickling out of the valve.. any ideas? Maybe because I didn't bled the LSPV.
