Weird Thing Happened Today. AC turned off.
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Jun 19, 2016.
  1. Jun 19, 2016 at 8:16 PM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Ok, so I was driving at about 50 mpg and was passing a truck and hit the accelerator hard. i don't think I redlined but I was up to 85-ish mpg. The air conditioning was on but then with the fan blowing the A/C turned off and the light on the A/C button started blinking. Air was still blowing but it was warm since it also stopped recycling the air.
    I pushed the A/C button but nothing happened, kept blinking. So then I turned the fan speed all the way down to turn the whole system off and then back on and everything was fine.
    It was weird must have either turned the A/C off to put more power to the drive train or maybe the serpentine belt slipped. Its working fine but it was weird and hasn't happened before.
    Anybody else ever experience this?
  2. Jun 19, 2016 at 8:34 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    If the rpms are above a speed (5500rpm example) the a/c should disengage.. that keeps the compressor from over driving and blowing out seals from too much pressure from too much rpms.
    Nor7[OP] likes this.
  3. Jun 19, 2016 at 8:40 PM
    Nor7
    Good to know. Thanks. I guess I'm surprised that I haven't rev'd it up that high before.
  4. Jun 19, 2016 at 8:47 PM
    Mike Tread lightly.
    south carolina
    I don't know what the ratio is, if it's one to one, on the compressor to crankshaft but 6000rpms is alot of flying metal in a small place.. then add oil and gas (freon) in the mix.
  5. Jun 20, 2016 at 8:16 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea interesting. Good feature to prevent failure.
  6. Dec 13, 2016 at 12:11 PM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Hey guys. This happened to me today, it's been over an hour since it's happened and it's still not working. I wasn't really haulin ass but might've pushed the rpms comin out of the court parking lot after sitting there for 4 hours for nothing. Anything I can check before I take her in?
  7. Dec 13, 2016 at 1:41 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hope you didn't damage the compressor.
    NewImprovedRon likes this.
  8. Dec 13, 2016 at 2:33 PM
    davesnothere
    Dave
    Down South, Texas
    Alright switched ac on an it's blowing air, the ac blows for a sec then the button starts blinking and the rpms bog a little. All dash lights and stuff are fine. According to ultra gauge highest rpm was 4652 at around that time, earlier in the month it shows I had higher, 5600 at one time.
  9. Dec 13, 2016 at 2:33 PM
    davesnothere
    Dave
    Down South, Texas
    Also it's new so it's still under warranty, was just hopin to fix it myself instead of wasting time down there at dealer
  10. Dec 13, 2016 at 2:54 PM
    davesnothere
    Dave
    Down South, Texas
    Read on the cable being loose as well, gonna check it soon. Will post update when I get ☝️
  11. Dec 13, 2016 at 6:49 PM
    Nor7
    Hmm, that's strange. When it happened to me, I turned the AC all the way off then back on and it came right back with no issues.
