Painting Center Caps
Discussion in 'General Tundra Discussion' started by Rex Kramer, Oct 13, 2019.
  1. Oct 13, 2019 at 3:05 PM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    Does anyone have experience, or suggestions on the best method to paint these center caps? It's a combination of mostly metal, and some plastic. I suppose scuffing them up with sand paper and applying primer would work, but what primer?
    Any suggestions would be appreciated - thanks.
  2. Oct 13, 2019 at 7:02 PM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    I have done it. To get the paint to stick you want to sand off that plastic film that is applied to the caps and rims. If you dont get it all off you may find it will chip. Aside from that use a quality spray paint, i used the metallic rustoleum line which is a primer and paint. Turned out great and holding up well.
    Rex Kramer[OP] likes this.
  3. Oct 14, 2019 at 2:31 PM
    Rex Kramer
    Georgia
    That was easy...
    Shaggie13, BestGen, GAknight and 4 others like this.
  4. Oct 14, 2019 at 2:52 PM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Lets see those on your rims! They look great
  5. Oct 15, 2019 at 6:23 AM
    Rex Kramer
    Georgia
    My first attempt at painting wheels, or most anything else for that matter.
  6. Oct 15, 2019 at 6:32 AM
    Nice job. :thumbsup:
  7. Oct 17, 2019 at 8:26 AM
    Rex Kramer
    Georgia
    I am rolling on my winter wheels & Michelin tires until hot temperatures return, that's when the TOYO Proxes ST III's are at their best.
    Spaceiscool and GAknight like this.
  8. Oct 17, 2019 at 5:21 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    I just got a used set of these wheels and one of the center caps is in ROUGH shape.
    Two questions:
    Do you just pull/pry to get those center caps off?
    Then any tips to getting the Toyota emblem off and reinstalling?
  9. Oct 17, 2019 at 5:42 PM
    Rex Kramer
    Georgia
    I pushed the center caps out from the back side with the wheel off. Squeeze the little split tabs on the back of the emblem together with needle nose pliers and push out gently, one at a time. Line the tabs on the emblem up with the slots in the cap and snap it into place using your fingers. It was surprisingly easy.IMG_7616.jpg
  10. Oct 18, 2019 at 2:53 AM
    Big Red 1969
    Big Red 1969 New Member
    Nice - looks good.
  11. Oct 18, 2019 at 12:25 PM
    Rex Kramer
    Georgia
    I was proud of the results... However, the finish was ruined during the balancing process because the solvent used to clean the inside of the wheels before attaching wheel weight tape reacted with the paint like acid.
    My local dealership performed the mount & balance, and they are going to have all 4 wheels professionally re-painted and sealed next week... I drop the truck off Monday afternoon. So it should look even better than before, and I will add the blue accents I have planned for these wheels after the dealer returns them.
  12. Oct 19, 2019 at 12:48 PM
    ND_Porkchop
    Whoa, that's nice of the shop considering it was a rattle can job.
    Automotive paint should hold up well if they prep it right and strip it all off.
  13. Oct 22, 2019 at 2:28 PM
    Rex Kramer
    Georgia
    I picked up the truck 1/2 hour ago, and the wheels look better than ever... better than I could have ever done myself. I am super impressed with my Toyota dealer stepping up and handling this issue without any fight whatsoever.
    Finch likes this.
