Lots of blue smoke on start
Discussion in 'General Tundra Discussion' started by 2015Crewmax, Oct 11, 2019.
  1. Oct 11, 2019 at 10:41 AM
    2015Crewmax
    2015Crewmax [OP] New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    Any info peeps?
  2. Oct 11, 2019 at 11:35 AM
    piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure. Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs.
