Plow recommendations
Discussion in '2.5 Gen Tundras (2014-2021)' started by motocrossman99, Oct 8, 2019.
  1. Oct 8, 2019 at 6:22 AM
    motocrossman99
    motocrossman99 [OP] New Member
    Josh
    2019 Barcelona Tundra SR5
    im considering getting a plow this winter. ive never had a truck before this winter what should i look for and what would be a good brand that is not going to break the bank. Thanks for everyones insight.
  2. Oct 8, 2019 at 6:34 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If your looking for a personal plow to do the drive the best one I've used over the years is the Snowsport plow.
    https://www.agricover.com/snowsport/
    I've had mine for two years and it works extremely well. It's also a lot easier on the truck compared to other plows I've used. Removing it is very easy, it's easy to store and you dont have to run a wiring harness.
    They do show an electric winch option but it really isn't necessary.
  3. Oct 8, 2019 at 7:12 AM
    motocrossman99
    Josh
    what kind of snowfall do you get in your area? the blade doesn't look tall enough for the snow belt i live i but i could be wrong.
  4. Oct 8, 2019 at 7:25 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    We have shovels bigger than that in Winnipeg. o_O
  5. Oct 8, 2019 at 7:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Depending on your area you can pay for a lot of snowplowing before you get to the cost of a new plow. New you're looking anywhere from $3-5k depending on options.
  6. Oct 8, 2019 at 8:29 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    We get anywhere between 2 to 4 feet. The heavy duty version is taller than the standard. I plow my drive that's about 50 yards long and two other driveways about the same length. Check out some of the YouTube videos and you will be convinced the plow is tall enough.
    Found the company video but there are also many private videos on YouTube.
    https://youtu.be/tlcKBVL6MFE
    BravoDeltaRomeo likes this.
  7. Oct 8, 2019 at 8:31 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm in Kenora and have never had any issues with the size.
  8. Oct 8, 2019 at 8:37 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Plow starts at 1,700 for the standard and 1,900 for the HD. I'm on my third year with the plow, 3 years of plowing with a contractor would be way more costly.
  9. Oct 8, 2019 at 9:05 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I personally wouldn't put a Snowsport on my truck just because I don't want to get out and angle or pick up the plow, so the $3-5k is for your Meyer/Boss/Fisher/etc.
    Like I said depending on the area. I can get my drive plowed for $20 so even at $1700, that's still 85 trips.
    I've had 3 trucks with plows and skipped it this time and went with one of these guys instead.
    1fujifilm and BravoDeltaRomeo like this.
  10. Oct 8, 2019 at 9:47 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Well there you go, you aren't far from me. We pass through Kenora often in the summer ok our way to your Ontario parks for camping. Much nicer than ours.
    Time to get a longer driveway so I can justify one. To be fair, I don't even think I pulled out our snowplow last year as we didn't get as much snow as previous years
  11. Oct 8, 2019 at 10:42 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    $20 bucks to do you driveway? If you have someone doing it for $20 why would even invest in a lawn tractor with a blower. Angling isn't that inconvenient. I angle only when its deep and run ones side then the other. The OP is looking for a cheap plow and this one is one of the best bang for the buck plows for personal use.
  12. Oct 8, 2019 at 10:46 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Last year we had an average amount of snow, about 2.5 to 3 feet. It's always strange to me that when we go into the city during the winter Kenora has 2 feet on the ground and Winnipeg has 6 inches.
  13. Oct 8, 2019 at 11:31 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I've got 2 acres to mow. I bought the 520, 60" deck, blower, weights, and chains for $1000.
    Our average annual snowfall here in NW PA is about 375cm (I did the conversion :)) it's not uncommon for us to get 1-2ft of Lake Effect overnight. Everybody and their neighbor has a plow here and most of them are plowing for beer money. There are 13 houses within a half mile and 6 have truck plows, 4 have farm tractors, and the others have walk behind blowers.
  14. Oct 8, 2019 at 11:59 AM
    2004lb7
    2004lb7 New Member
    Ian
    Boss plow. Tows trailers everyday.
    I have a Boss Standard Duty on my Tundra. I plow HOAs and private homes. It can hold any plow just fine up to 700 pounds. If I had to buy another I'd go for a Western Pro 8'.
  15. Oct 9, 2019 at 5:23 AM
    motocrossman99
    Josh
    alright thanks for everyone's input. ill keep looking up some videos on these and see what will work for me. i was thinking about using it for personal use and maybe making a few buck on neighbors driveways as well.
  16. Oct 9, 2019 at 7:24 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    In today's world check with your insurance. As soon as you collect a payment you assume all liability for slip and falls or damage. Not saying it will happen but it only takes once to send you up the creek.
  17. Oct 9, 2019 at 7:45 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    im pretty sure plowing will void factory warranty too. I would never ever plow with a tundra.
    i second the garden tractor idea!
    or a deere?
    Festerw likes this.
  18. Oct 9, 2019 at 8:17 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    The Deere
    B737 likes this.
  19. Oct 9, 2019 at 8:25 AM
    B737
    Jersey Shore
    LOL! awesome
  20. Oct 9, 2019 at 8:31 AM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I’ll be installing the 8’ fisher hd2 off my 2500hd on my tundra. It goes in for truck side wiring on the 6th of November.
