RPM's at startup?
Discussion in 'General Tundra Discussion' started by Jackdiesel0688, Oct 8, 2019.
  1. Oct 8, 2019 at 10:43 AM
    Jackdiesel0688
    Jackdiesel0688 [OP] New Member
    2014 Platinum Crewmax
    Body matched mirrors and door handles.
    I have noticed my 2014 CM with the 5.7 idles high at startup. 1400rpm when it's almost 70 degrees outside seems kind of high. It will hold that for a minute or two. I understand when the engine is cold it will idle higher but what is everyone's truck idle at on startup? I want to say once the engine is warm it idles at 6-700rpm.
    YardBird and Rica25 like this.
  2. Oct 8, 2019 at 12:39 PM
    Rica25
    Ricardo
    Tulare
    Myv2008 has been the same since new and still does the same now
    YardBird likes this.
  3. Oct 8, 2019 at 1:08 PM
  4. Oct 8, 2019 at 1:52 PM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    It is normal
    Rica25 and YardBird like this.
  5. Oct 8, 2019 at 1:54 PM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    as long as its not surging then 1400 is completely normal
  6. Oct 8, 2019 at 2:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Similar to a choke like the old days, fuel injected cars and trucks do something similar when started. You’re just going to notice it more on a bigger engine like the 5.7 L.
    Rica25 likes this.
  7. Oct 13, 2019 at 6:25 PM
    jvt3
    jvt3 New Member
    I was very surprised to see the high idle (around 1300rpm I think...) when I first turned on my 2019 truck....but mine STAYS high a very long time (if it's not been driven
    for a few hours, but regardless of outside temperature),. Although I sit there a few minutes before driving (hoping it will decrease), it never does (even after
    5 minutes or more)..so. I just drive..but its wierd to hear that big drop in RPM's when putting it in drive....doesn't bother me if that's considered normal.
  8. Oct 13, 2019 at 8:40 PM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    Mine does it. If someone is standing near the exhaust i have learned to wait for them to move a few more feet before i start just not to spook them.
    Rica25 likes this.
  9. Oct 13, 2019 at 8:54 PM
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Mine seems high after it settles down. I notice at a stop light that I need to keep a steady pressure on the pedal to keep it from creeping forward. I say mine is around 900-950. Is that normal.
    Rica25 likes this.
  10. Oct 13, 2019 at 10:22 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Yes, all of that is normal.
    I have sciatic nerve pain through my right ankle which makes it painful to press and hold the brake pedal for long periods of time. I have learned to put it in neutral if I’m at a long stoplight.
  11. Oct 13, 2019 at 11:02 PM
    Aerindel
    Aerindel New Member
    Montana
    Mine is more like 2K for the first few seconds, then settles down to about 1200 until the engine is warm.
    Rica25 likes this.
