Serious confusion
Discussion in '1st Gen Tundras (2000-2006)' started by White&BlueRocket, Oct 3, 2019.
  1. Oct 3, 2019 at 3:46 AM
    White&BlueRocket
    White&BlueRocket [OP] New Member
    Jerrett
    2000 White Tundra 2WD V6 5VZ-FE
    New radio, new seals, fuses and relays.
    I have a slight issue.
    I need to know what part this is in the HVAC Assembly and where i can get one. I noticed when i bought the used truck that it barely wanted to switch between Heat to A/C or vise versa. One day I was switching it and head a snap sound. It got stuck on Heat and the knob felt like it was free spinning. I pull the dash and see plastic dust fall out, I knew i had broken something plastic. Turns out there is a little gear plate with two holes for the steel cables that control the heater valve and blender. Now i have to newfangle my heater on and off via opening the hood and turning the valve to open and then I ran my other to my glove box so i can control the blend as well.
    This is a huge hastle to me and is very inconvenient. My local toyota guy doesn't even know what it is, he said it's not in the parts list only the whole control unit. I just need the new gear, I've oiled and freed up all 3 steel cables but now I need the gear. I'll post pictures if asked or if I have any.
    The part is also creamish tan colored is that helps, it has a kind of twin for the vent door control.
  2. Oct 3, 2019 at 3:56 AM
    TokerJoker and remington351 like this.
  3. Oct 3, 2019 at 4:09 AM
    White&BlueRocket
    Jerrett
    @bmf4069 thank you for replying so fast.
    Sadly my local pull apart doesnt have a 1st gen tundra and neither do any of the ones in a 100 mile radius. I think I might just have it 3D printed after i get the ok from toyota to do so. I'll 3D print both gears, spindles and knobs in metal so I wont ever have to worry about breakage again.
    TokerJoker and Patch999 like this.
  4. Oct 3, 2019 at 4:25 AM
    If you made a bunch of em I bet people on here would buy em. Hell, I probably would.
    TokerJoker, Pinay and Sunnier like this.
  5. Oct 3, 2019 at 5:36 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    www.car-part.com shows a bunch under $50. Can't imagine shipping would be too crazy.
    TokerJoker likes this.
  6. Oct 3, 2019 at 5:53 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Now I'm confused, why would you wait to get an OK from Toyota to 3D print a homemade part for yourself that they won't sell you...o_O
  7. Oct 3, 2019 at 6:45 AM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, I can’t see any reason why Toyota would give you permission to manufacture something they own. Unfortunately, it’s not uncommon for Toyota to sell “system” parts, but not individual components.
  8. Oct 7, 2019 at 11:00 AM
    deke1691
    deke1691 New Member
    NorCal
    2000 AC V8 2wd
    Agree. Why ask? Besides, lots of companies make replacement parts. I don’t think they ask Toyota if they’d mind. :)
  9. Oct 7, 2019 at 1:58 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I have an extra hvac assembly because I’m swapping cabs on my Tacoma. I will see if I have one. No promises though.
  10. Oct 7, 2019 at 2:21 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Just make what you need. If problem solved Yota don't need to know. It's YOUR truck.
