06 Tundra Transmission oil change, What fluid?
Discussion in '1st Gen Tundras (2000-2006)' started by bugtussell, Oct 5, 2019.
  1. Oct 5, 2019 at 3:50 PM
    bugtussell
    bugtussell [OP] New Member
    Brayden
    06 Tundra 4.0 V6
    What fluid do i put in my 06 4.0 v6 Automatic tundra? It has 131k on it. I just bought it today not sure its history seems to be very well taken care of tho. Thinking about doing a fluid flush and change also changing the rear dif fluid
    because_wumbo-truck and YardBird like this.
  2. Oct 5, 2019 at 4:51 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  3. Oct 5, 2019 at 5:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sealed trans. So it’s a little more involved to do, but can be fine diy with a measuring container and a pump. The truck takes Toyota WS transmission fluid, so anything stating compatibility with that should be fine
  4. Oct 5, 2019 at 5:50 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    With a sealed transmission is there a filter to replace? Ive seen the process of it being done in a video but don't recall seeing them replacing any filter
  5. Oct 5, 2019 at 6:07 PM
    empty_lord
    05 rollover special
    If you drop the pan the is
  6. Oct 6, 2019 at 5:30 AM
    growit
    growit New Member
    2006 Dbcb SR5
    I have the dealership flush my 2006 trans every 100k miles or so, that's the only thing I use the dealership for.
  7. Oct 6, 2019 at 9:45 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You a smarter for this as the stealer has all the proper equipment.
    The earlier first gens (2000-2002) are an easier diy project much like doing and oil change but much simpler.
    YardBird likes this.
  8. Oct 6, 2019 at 9:56 AM
    empty_lord
    05 rollover special
    You would be surprised how many dealers charge you for a flush, and do a drain and fill.
  9. Oct 6, 2019 at 10:11 AM
    Fred
    Hand Protectors
    True.
    As you work in a dealership, this must frustrate you. A real total fluid change versus a drain and fill (1/3 change) is night and day labor wi$e.
    I’ve trusted my dealer for years to do the right thing, but who knows? This is the main reason for me taking over my own maintenance. With that being said, the sealed transmissions (in later first gens) seems like a no brainer dealer job with all the exact temperature and special fuse box pins, etc needed to perform the job.
    Seems like one could easily do diy on the sealed transmission very easy if the intervals were performed at shorter miles and it was the drain and fill type of changes (assuming the drain was measured correctly and the proper amount reinstalled).
    N84434 and YardBird like this.
  10. Oct 6, 2019 at 11:05 AM
    empty_lord
    05 rollover special
    working in a dealer i do see alot of frustrating things. lol but sadly i have to deal with it. i'll do what im paid to do. others will take shortcuts.
  11. Oct 6, 2019 at 6:12 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    I don't feel like its that hard from tutorials I've seen, but I kinda like learning this stuff anyways. I have a Milwaukee temp gun I can borrow and I bought a pump for the fluid. I'm also thinking about seeing if I can get Toyota tech stream set up on my computer so I can just read the temp from the sensors.
    Now time-consuming yes, it takes me a while just to do an oil change so this will probably take me half a day.
  12. Oct 6, 2019 at 6:15 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    Oh also had to order a measuring cup big enough to measure the old fluid.
  13. Oct 6, 2019 at 6:48 PM
    empty_lord
    05 rollover special
    No real need for a level check if you measure what comes out and put exactly that back in. Do it with the trans cold too.
    Unless you have a leak
  14. Oct 6, 2019 at 8:51 PM
    I plan on using amsoil, signature series fuel effiecent synthetic atf fluid. It’s WS compatible. That’s what I used when I did a fluid flush/swap(tranny pump) on my ‘10 4runner.
    bugtussell[OP] likes this.
  15. Oct 11, 2019 at 4:58 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    That's exactly what I am using! Already ordered along with ams oil signature series oil and filter
