What is this?
Discussion in 'General Tundra Discussion' started by tbrown, Oct 1, 2019.
  1. Oct 1, 2019 at 5:16 PM
    tbrown
    tbrown [OP] 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Anyone know what to search for to replace this strip missing? @Roman ?
  2. Oct 1, 2019 at 5:24 PM
    AZTundra
    Paul
    Phoenix, AZ
  3. Oct 1, 2019 at 5:29 PM
    Mnorris1206
    08 tundra
    Idk the part number but my wife had a highlander that would loose those in a car wash everytime eventually the dealer put some silicone where the meet up at the clips then it never came off again.
    Kerch71 and Pinay like this.
  4. Oct 1, 2019 at 5:33 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    I began to lose mine on the driver's side a few months ago on my 2015. Applied some 3M spray adhesive, taped it down for the night and it has stayed put for months now.
    Sorry you lost yours!
    Black Wolf, Pinay and tbrown[OP] like this.
  5. Oct 1, 2019 at 5:49 PM
    tbrown
    Nashville, TN
    Pinay likes this.
  6. Oct 1, 2019 at 5:50 PM
    tbrown
    Nashville, TN
    Pretty sure it was the drive through car wash or low branches while off roading. I’ll definitely slap some adhesive when replacing
    Pinay likes this.
  7. Oct 1, 2019 at 5:51 PM
    AZTundra
    Paul
    Phoenix, AZ
    No problem. Make sure to look and see if you also need the clip - I believe those are sold separately for a couple dollars, not sure if you lost that also.
    tbrown[OP] and Pinay like this.
  8. Oct 1, 2019 at 11:08 PM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
    Known issue. Your local Toyota dealer should just hand one over. I’m on my third.
  9. Oct 2, 2019 at 3:20 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Happened to me on my Tacoma 2012
    Dealer gave me one and it was out of warranty
  10. Oct 2, 2019 at 3:52 AM
    Skip_TRD_Sport
    Skip_TRD_Sport Less is More.
    2019 Cavalry Blue TRD Sport
    Westin Pro Traxx 4 Step Bars, Bed Mat, Color Matched Door Handles
    I purchased my truck new in July and the dealer was a 5 hour drive from my home. I had one pop up on me on my ride back. I was able to apply some good pressure on it to make sure it grabbed the clip. Additional adhesive would be advised.
  11. Oct 2, 2019 at 4:23 AM
    War Machine
    War Machine SSEM # 5 3MW
    These are known to come off quite a bit. I had one come loose while going 80 miles an hour on the freeway once. It started slapping the cab of the truck and scared the hell out of me. I didn’t lose it, so I just got some automotive glue and stuck it back down.
    Since you lost yours, I’d see if the dealer will just give you one.
  12. Oct 3, 2019 at 9:39 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It is definitely an issue. We sell the crap out of these, and on different models besides the Tundra too.
    tbrown[OP] likes this.
  13. Oct 3, 2019 at 9:46 AM
    tbrown
    Nashville, TN
    Picked one up from y’all yesterday while getting oils changed, good to go again!
    AZTundra and Roman[QUOTED] like this.
