Oil type??
Discussion in 'General Tundra Discussion' started by West Texas Tundra, Sep 28, 2019.
  1. Sep 29, 2019 at 5:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes definitely DIY if you can. You save half that at least. Plus you know you’ll do it right with no screws missing when you’re done. Plus just think of it as bonding time lol.
    Rica25 likes this.
  2. Sep 29, 2019 at 5:53 PM
    West Texas Tundra
    West Texas Tundra [OP] 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    Right. I’m just missing the torque wrench.
  3. Sep 29, 2019 at 5:53 PM
    Nothing to apologize for at all Leo! Occasionally my local dealer has a decent deal on Toyota motor oil, but we have at least one member, if not two, who will post at least twice a year a huge Walmart discount/rebate for Mobil 1. After all is said and done, the Walmart deal with oil and filter after rebates is like around$30:thumbsup:
  4. Sep 29, 2019 at 6:40 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Yea that’s a good deal when you can get a rebate. How long does the rebate take to get back to you?
    Black Wolf likes this.
  5. Sep 29, 2019 at 6:43 PM
    Rica25
    Ricardo
    Tulare
    For the last 11 yrs I have ran Mobil 1 and Valvoline maybe a handful of times only .....truck runs like new still..... I do add at every oil change BG additive for the oil and fuel tank I have 144k miles
  6. Sep 29, 2019 at 6:44 PM
    I'm not sure how long but I'm sure someone might chime in about that Walmart deal who may have done that. I know the response is quite good when the rebate/deal gets posted.
    Rica25 likes this.
  7. Sep 29, 2019 at 8:06 PM
    Toyota and Audi guy
    Toyota and Audi guy New Member
    Stephen
    2018 Tacoma SR access cab 2.7 4wd
    I have used Mobil 1 since 1977 in a Pinto Squire. Put 114k on it before I totaled it in 79.I sold Toyota from 82 ro 97. Have used it,recommended it to this day. My Audi dealer uses Castrol inmy 08 A4 avant with 143k. 2.0 turbos burn oil and when I top it off,I use M1.My 18 Tacoma at 22k with the 2.7 is a sweet runner. Thank you Toyota for listening to me.
  8. Sep 29, 2019 at 8:10 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Below is a picture of the Toyota part number most people use for this mod. You can see that it clearly says "TOYOTA" on the side of it. You reuse the bottom plug, center perforated tube, and spring from the original plastic housing.
    https://www.amazon.com/Genuine-Toyo...5SD30PXGA5H&psc=1&refRID=YD8TXAMCQ5SD30PXGA5H
    Do your oil changes yourself. It would worry me if they felt they screwed up so bad they needed to comp the oil change. What are they NOT telling me? Hmmmm.
  9. Sep 30, 2019 at 3:26 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Well guys I took some pictures, didn’t see a Toyota logo on there so I’m guessing it’s dorman. I think I saw a made in China marking on the side. What y’all think?
    So now I’m really bugged about the center piece for the filter. Need to have a look.
    also, all the videos I’ve seen, the center piece is removed In order to let the oil out of the filter canister. This center piece doesn’t look like it can be removed.
  10. Sep 30, 2019 at 6:09 PM
    JohnLakeman
    The Toyota housing has a round flat plug on the bottom of the housing. I can't tell if that Chinese housing has a bottom plug or not. The Dorman appears to be configured just like the Toyota housing.
    Here is a YouTube video showing the Tundra center perforated tube being retrofitted to a new Toyota aluminum housing. There are many more videos on topic. Search YouTube for Tundra oil filter housing upgrade and watch as many as you need.
    https://www.youtube.com/watch?v=V7CyIi4fVt4
    West Texas Tundra[OP] likes this.
  11. Sep 30, 2019 at 6:56 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Hmm. Yea I had seen that one before. Just thinking that if these guys didn’t switch the large center stem from the original filter over the the new one, how long does the filter last before it collapses?
  12. Sep 30, 2019 at 7:19 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I just put the Toyota one in....looks like this:
    415E3A65-F1E8-4CDF-A4B2-3BB7F5C5E4E0.jpg BA4EFCC3-7ED6-42FA-AAF1-1C1E895F96EE.jpg 8A6DBB5B-62F5-4EB7-BFA4-358E418AFE3F.jpg
    I did swap out the middle section.
    15whtrd likes this.
  13. Sep 30, 2019 at 7:38 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Thanks bro, yea mine for sure isn’t a Toyota style. My concern now is that if these guys didn’t swap out the center piece, I probably can’t get a replacement unless I get a whole new set up.
    15whtrd likes this.
  14. Sep 30, 2019 at 8:24 PM
    JohnLakeman
    If I were in your position, I would not drive the truck until I removed the housing and inspected the center tube. You do not want that filter element to come apart and send paper particles into bearing oil passages.
    Go to your local dealer (or @Roman ) to see how quickly he can get you a Tundra housing with the long center tube...it'll likely take at least several days. You can do this after your inspection if you have the time. If you find the oil change wizards used the proper center tube for the Tundra filter, reinstall the filter and housing and add oil to make up for the spillage. That would give me peace of mind. If you find they left the short tube in the housing, you'll need to either use the Tundra plastic housing from the dealer or swap the long tube into the Chinese housing. Once you verify the center tube length, you can decide what you want to do from there.
    15whtrd likes this.
  15. Oct 1, 2019 at 10:53 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Well i verified that’s it’s a dorman. Problem is I still don’t know if the center tube is the right length.
    probably a stupid question but can you remove the oil filter cap without losing all the oil?
    can you purchase just the center tube from dorman or Toyota?
  16. Oct 1, 2019 at 11:18 AM
    JohnLakeman
    Yes, you can remove the filter without losing all the oil. With a drain pan underneath, and proper oil filter wrench, unscrew the main filter housing and carefully lower it down into the drain pan. You'll spill a little bit over the top of the housing, but you can simply replace that with fresh oil through the top filler. Press the filter element down against the spring tension to the bottom of it's travel. If the top of the tube is near flush with the top of the filter element, you're OK, you have the right center tube.
    Purchasing just the center tube from either source is doubtful in my opinion.
    15whtrd likes this.
  17. Oct 1, 2019 at 11:31 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Thanks lakeman! Much appreciation for your knowledge. Sounds like I’ll have a busy weekend.
    TXRailRoadBandit73 likes this.
  18. Oct 1, 2019 at 12:13 PM
    JohnLakeman
    If you have Amazon Prime you can probably get the tools and materials you need for changing your own oil before the weekend if you order now:
    Filter housing wrench: https://www.amazon.com/Motivx-Tools...JYQR3Z30YYS&psc=1&refRID=ETV2EPQJQJYQR3Z30YYS
    Not needed this weekend, but for future changes:
    Mobil 1 EP 0W-20 (2 req'd): https://www.walmart.com/ip/Mobil-1-Extended-Performance-Full-Synthetic-Motor-Oil-0W-20-5-qt/36019107
    Oil drain plug gaskets: https://www.amazon.com/Genuine-Toyo...PHEK5KJR35X&psc=1&refRID=BVXRG8177PHEK5KJR35X
    Filters (2): https://www.amazon.com/Set-Toyota-0...PHEK5KJR35X&psc=1&refRID=BVXRG8177PHEK5KJR35X
    Note this filter part number includes the filter housing O-ring gasket (must be installed correctly, see instructions on filter element box), O-ring gasket for housing drain plug, and a pretty useless plastic housing drain valve. Filter elements come both with and without the O-ring gaskets...make sure you're getting the gaskets with the element or you have to buy separate. They must be changed every time.
    If you want to prevent the oil from running down your hands and arms like it will this weekend, I recommend the wrench and drain hose combo below (use instead of wrench listing above). If you don't mind a little oil running off your elbow, you can do without the drain hose:
    https://www.amazon.com/Motivx-Tools...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    Torque Values:
    Oil pan drain plug = 30 ft-lb
    Oil filter housing = 18 ft-lb
    Oil filter housing drain plug = 9 ft-lb
  19. Oct 1, 2019 at 12:24 PM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Thanks again! I owe you brew, or maybe even a 12 pack.
    How do feel about the fumoto or ez drain valves?
  20. Oct 1, 2019 at 12:40 PM
    #50
    JohnLakeman
    Never used them. They are probably convenient, but I don't like a quarter turn valve that could open up and drain my oil pan without me knowing. (Yeah, yeah, for all their champions, I'm sure they're foolproof and would never do that. :D) I like a drain plug that screws in and is torqued, but that's just me. I would never try to talk anyone out of using one.
  21. Oct 2, 2019 at 6:16 PM
    #51
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    No one mentioned. Amsoil.
    Are there any Amsoil users here
    It all I use have for 20 yrs.
  22. Oct 2, 2019 at 6:56 PM
    #52
    ProtoJ
    ProtoJ New Member
    Also....if you do ever add a fumoto valve....mines got a plastic clip that locks the lever from moving and a rubber cap on the end.
  23. Oct 2, 2019 at 8:22 PM
    #53
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Thanks Proto, man I do like those. I feel that it would be very unlikely that the valve handle would move while under driving condition. You have to lift and move to the right, correct?
    but that retaining clip gives peace of mind.
    15whtrd likes this.
  24. Oct 2, 2019 at 8:25 PM
    #54
    ProtoJ
    ProtoJ New Member
    Correct, move the clip, push the lever and side to the right . It’s also spring loaded lever so it has a few safeties. Plus is does sit up out of the way snagging on something would be unlikely.
  25. Oct 4, 2019 at 5:14 PM
    #55
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Talking about oil changes. What do you guys use to contain your used oil? I’ve bought the plastic ones but the only last 2 or 3 times before some thing snaps off.
    Has any one seen a metal option?
  26. Oct 4, 2019 at 5:28 PM
    #56
    ProtoJ
    ProtoJ New Member
    I just use a plastic oil pan with no parts or lid and then pour it into the empty Mobil 1 jugs.
  27. Oct 4, 2019 at 6:15 PM
    #57
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    I drain into a oil pan then pour back into oil jugs, head over to advanced auto parts and dispose of it.
  28. Oct 4, 2019 at 6:18 PM
    #58
    I got the same
  29. Oct 4, 2019 at 6:28 PM
    #59
    What I have...
  30. Oct 12, 2019 at 12:16 PM
    #60
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Anyone run the k&n oil filter on their rig? I’ve always liked their air filters but didn’t know if there was a difference In filtration when it comes to oil.
