Steam vs Extraction?
Discussion in 'Detailing' started by Sas, Oct 2, 2019.
  1. Oct 2, 2019 at 11:38 AM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  2. Oct 2, 2019 at 12:06 PM
    War Machine
    War Machine SSEM # 5 3MW
    I actually have both of those. We got them for the house, but I’ve tried them on vehicle interiors. The Bissell works very well, but I haven’t had much success with the McCullogh steamer. I know a lot of detailers recommend them, so I just may not be using it properly.
    I just got a Tornador gun a couple of days ago. I haven’t had a chance to really use it yet. It’s supposed to be amazing on fabric though.
    I tried it on one wheel, a wheel well, grill, and badges for a few minutes. It really did work very well. On the wheel it was limited by what I could reach. I couldn’t get it between the spokes.
    https://youtu.be/WYiac9Sh89Y
  3. Oct 2, 2019 at 1:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    @Sas I have been looking pretty hard at the tornado cleaner that Jason posted. They really seem to be extremely effecting and versatile. I saw one on TV last night being used to clean a 30 year old truck frame during a restoration project. It worked very well and was super fast. The uses for something like this seem to be endless and certainly range well beyond just detailing vehicles. The idea is pretty simple and it looks very effective. If you have or are planning to get a decent shop air compressor then for me, this would be a no brainer. One day I hope to own one and once I get it, I will use the hell out of it all over the house, garage, and cars
    ColoradoTJ, War Machine and Sas[OP] like this.
  4. Oct 2, 2019 at 2:01 PM
    Sas
    OKC, OK
    That tornado gun looks pretty slick. The main reason I'm looking at these things is to remove dog odors from slobber/drool, their oils, etc, as well as some of the dirt/mud stains they track in. Without an extractor it seems the steam would just push that stuff down into the seat foam. I'm also worried the chemicals and/or steam would compromise the glue on the headliner. I'd also like to use it indoors on the furniture.
    War Machine likes this.
  5. Oct 2, 2019 at 3:44 PM
    War Machine
    The steamer is supposed to be great, but I’ve just not been able to get it to work for much. My wife ordered it before I even got into detailing. Same as you, I don’t see where the chemicals go without extraction.
    That Bissell unit you linked is pretty handy, and I’ve gotten some good use out of it. Even with that, I still sometimes have to use a scrub brush first.
    saybng and Sas[OP] like this.
  6. Oct 2, 2019 at 3:58 PM
    Sas
    OKC, OK
    Maybe the best bet is to get both and just use the steam to loosen up hard stains/odors so the extractor can pull them out?
    NUDRAT and War Machine like this.
  7. Oct 2, 2019 at 4:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Link? Looks like just the kind of magic i need to clean my commuter
    also, what fluid are you using?
  8. Oct 2, 2019 at 4:09 PM
    War Machine
    Got it during an autogeek 25% off sale. I have only used water so far. I only messed around with it for a little while the other day.
    Sas[OP] likes this.
  9. Oct 2, 2019 at 4:10 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I have the Bissell, originally purchased for home use, but we used it on our Honda with cloth interior and it worked pretty well. We left the doors open for a couple hrs to let the breeze come through. So far so good..:thumbsup:
    Sas[OP] likes this.
  10. Oct 2, 2019 at 4:21 PM
    Danimal86
    Daniel
    Sacramento, CA
    wowza, 2-hundo.......might try one of the cheap-o's from Amazon.
    I think i'm gonna try this guy:
    https://smile.amazon.com/dp/B07SMZHY28/ref=psdc_15718281_t5_B07QVK4L77
  11. Oct 2, 2019 at 4:28 PM
    Sas
    OKC, OK
  12. Oct 2, 2019 at 4:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    There are a couple different models on Amazon, some have a metal spinner in the cone, others have a flexible tube, i opted for the one closer to the tornado (the metal spinner).
    Pudge and Sas[QUOTED][OP] like this.
  13. Oct 2, 2019 at 4:37 PM
    saybng
    Gary
    Ventura CA
    So the tornado shoots out steam/liquid..do you still need to vaccum the residual liquid?
    Sas[OP] likes this.
  14. Oct 2, 2019 at 4:42 PM
    Sas
    OKC, OK
    From what I've gathered yes, or use some sort of air mover. Sucking it out makes more sense to me tho so you're extracting all of the dirty water/chems too. I was thinking of just using a wet/dry vac at first.
  15. Oct 2, 2019 at 4:44 PM
    saybng
    Gary
    Ventura CA
    Uhuh..gotcha.
  16. Oct 2, 2019 at 5:02 PM
    War Machine
    I’ve actually been looking at this thing for a couple of years. I’ve seen several reviews of the knock offs. They for the most part say they work, but break pretty quick.
    Sas[QUOTED][OP] likes this.
  17. Oct 2, 2019 at 5:07 PM
    War Machine
    No steam. It circulates compressed air really rapidly. You can mix cleaning chemicals in the bottle, or just use water.
    Depending on the surface and how dirty it is, you can go over it with the liquid, then switch to air only and dry. For carpets or really nasty stuff I’d recommend going back over it with a shop vac.
    I’ve barely used it so far. I hope to do a complete review soon.
    Also, the previous model is cheaper. It isn’t as powerful as the new one. The cones also wore out on the old ones, and this one is supposed to be more durable.
    If anyone is looking at getting one of these, check the air compressor requirements. I believe you need 90 psi and 4 cfm. It also blows through air quickly, so the bigger the tank the better.
  18. Oct 2, 2019 at 6:06 PM
    Danimal86
    Daniel
    Sacramento, CA
    It should be here on Friday. Hopefully I'll get a chance to mess with it then. Grabbed a small bottle of CG upolstry cleaner to go with
    War Machine[QUOTED] and Sas[OP] like this.
  19. Oct 4, 2019 at 5:10 PM
    Danimal86
    Daniel
    Sacramento, CA
    @War Machine
    Mine arrived today. Can you post some pictures of iyours up close to compare?
    Sas[OP] and Pudge like this.
  20. Oct 5, 2019 at 4:49 PM
    Danimal86
    Daniel
    Sacramento, CA
    So I got a little bit of time to mess with my tornado knock off.
    I filled the container about half way with distilled water, and put in a couple squirts of chemical guys upolstry cleaner, cranked up the compressor and gave it a shot.
    My commuters car door panel was kinda bad:
    Before:
    After:
    Tundras seat:
    Before:
    After:
    It may taking more messing with it, but not the best results. I found that you need a lot of air at around 135psi. You also need to keep the end of the nozzle up against the upolstry.
    Stroke250, Pudge and Sas[OP] like this.
  21. Oct 5, 2019 at 5:15 PM
    Sas
    OKC, OK
    Thanks for posting those. If you get better results by doing something else, let us know!
  22. Oct 6, 2019 at 2:10 PM
    War Machine
    I’ve not been able to mess with mine really. My back has been in bad shape lately, so I haven’t gotten anything done.
  23. Oct 6, 2019 at 2:11 PM
    Danimal86
    Daniel
    Sacramento, CA
    Sorry to hear that. Hope it feels better soon!
  24. Oct 6, 2019 at 2:12 PM
    War Machine
    Me too. This stinks!
  25. May 13, 2020 at 5:34 PM
    owb2gp
    owb2gp New Member
    ID
    Any new suggestions for a carpet shampooer?
    Just need to clean stains here and there but would be nice to shampoo carpets in vehicles and seats when kids spill drinks and such.
    I'm looking at these:
    https://www.amazon.com/dp/B07Q2MKX5C/ref=cm_sw_r_other_apa_i_WdjVEbM93JFMD
    https://www.amazon.com/dp/B07D46SQ63/ref=cm_sw_r_other_apa_i_nhjVEb2R014NA
    I'm open for any suggestions under $250. Only to be used on personal vehicles. Just want something that works.
    Thanks!
  26. May 13, 2020 at 7:38 PM
    briarpatch
    briarpatch New Member
    I have the first machine you posted....got it on a Black Friday sale at Lowes 2 tears ago. It has done a very good job for me and has been very reliable.
    owb2gp[QUOTED] likes this.
  27. May 13, 2020 at 8:44 PM
    owb2gp
    owb2gp New Member
    ID
    Thank you! @briarpatch
